Installing Armbian of Nano Pi neo on neo air?
Rami Khawaly
Just now, Rami Khawaly said:
Thanks.
So i guess the opposite way will work?
I mean, NanoPi Air img will work on Neo/Duo?
And is there any way to pre-configure it so same image will be configured differently for each type?
AIR image has disabled ethernet ... but you can try to enable it. I don't recall if that is all.
We merge images when it's possible (without regressions) and if we find the time. In this case, you will need to play with board configuration (DTB) and u-boot settings (to enable eMMC support).
