ramawatar Posted July 24, 2018 Share Posted July 24, 2018 what difference between armbian and debian Linux Sent from my Redmi Note 4 using Tapatalk Link to comment Share on other sites More sharing options...
Igor Posted July 24, 2018 Share Posted July 24, 2018 18 minutes ago, ramawatar said: what difference between armbian and debian Linux Sent from my Redmi Note 4 using Tapatalk 2 I am not sure if this is what you want to know, but: - Debian.org or Ubuntu.com officially does not support any of those boards/boxes, - Armbian userspace has many small but vital performance or security adjustments, - Armbian fancy some kernel development and a lot of its maintaining. Debian relies on upstream sources for ARM hardware which can be years behind and/or lack of many functions, - Armbian userspace is lean, clean but 100% Debian (or Ubuntu) compatible - many stock Debian bugs are fixed on the way, "better than original :)" - a build system is a central part of this whole ecosystem. You can DIY. Debian much harder. - dedicated support forums per boards/boxes - plug and play vs. complicated install scenarios on Stock Debian - unified development scenarios and user experience vs. mess of different setup instructions scattered all around I must have forgotten many other important points 9 Link to comment Share on other sites More sharing options...
borekon Posted April 7, 2020 Share Posted April 7, 2020 Sorry for bumping this old threat, but it's the best so far i've found googling around 1 Link to comment Share on other sites More sharing options...
