eMMC device not Detected by armbian on nanoPi duo core
board: http://nanopi.io/nanopi-neo-core.html
image: Armbian Bionic mainline based kernel 4.19.38 from https://www.armbian.com/nanopi-neo/
after "nand-sata-install" I can see system copy on emmc (by mount /dev/mmcblk1p1 /mnt)
UUID in eMMC copy of armbianEnv.txt is correct for eMMC
"poweroff"
remove SD-card
power on
no system start. U-boot shell only with "no MMC card" messages
please advice what to check/fix more?
Most likely support for eMMC is missing from u-boot. Something like this https://github.com/armbian/build/commit/0aa08731aae4ba72548672ea036436fcc8fce320 has to be added to Nanopi Neo dts, recompiled and flashed to eMMC.
thank you for quick respond, Igor
as I understod that patch must be applied to the some src of u-boot program and then image must be rebuilt, isn't it? Actually I didn't try it before.
or can I decompie a current .dtb file for nanopi-neo from /boot/dtb/ folder to the *.dts file, then some modifiations similar to your patch and then comile a .dts file to the new .dtb file. Possible?
martinayottte, I've install a virtual ubuntu machine acoding https://github.com/armbian/build on my PC
run ./compile.sh
script has loaded a sources for kernel and u-boot.
After revision results I found that patch applied for sun8i-h3-nanopi-r1.dts and ..du2.dts only
sun8i-h3-nanopi-neo.dts (I'm using nanopi neo core so I suppose that file will be used for u-boot/kernel compilation) wasn't changed for mmc.
So I suppose I have to add similar rows about &emac and &mmc2 into sun8i-h3-nanopi-neo.dts
Then compile.sh again and what then?
copy a binary u-boot to to the SD-card of NanoPi Neo Core board, "nand-sata-install". Right?
Please confirm.
Right ! But &emac is not need, only &mmc2 ...
Compile using "ub-ooot + kernel only", no need for a complete image !
The resulting u-boot is cache/sources/u-boot/v2019.04/u-boot-sunxi-with-spl.bin, copy that on your nanopi, and from there :
dd if=u-boot-sunxi-with-spl.bin of=/dev/mmcblk2 bs=1024 seek=8
Then reboot without SD !
martinayotte, something wrong I'm doing...
attached .dts file - I've added a &mmc2 section only
attached .dtb file - result after compilation
all that files from ./cache/sources/u-boot/v2019.04/arch/arm/dts folder
in virtual machine start script ./compile.sh again
"U-boot and kernel package" selected
"Do not change kernel configuration" selected
"nanopineo" selected
"next Mainline" seleted
.... what is strange the script is cheking the git for orangepi board... anyhow let's wait....
..continue for a long time....
... finish
.deb files have been prepared in ./output/debs
a new "u-boot-sunxi-with-spl.bin" copied from Virtual machine to the /tmp folder of NanoPi
in NanoPI shell runs "dd if=/tmp/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1 bs=1024 seek=8"
(also I've run "dd if=/tmp/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1p1 bs=1024 seek=8" because system copied to /dev/mmcblk1p1)
SD-card removed
result?.... - no result. still u-boot shell available.... (((
Questions:
may be some files must be renamed?
may be .deb files must be copied also?
what else could be wrong?
Thank you in advance
sun8i-h3-nanopi-neo.dtb sun8i-h3-nanopi-neo.dts
If you edit DTS directly in this folder, each time you start a new build, your changes are reverted ...
After having edited the file, your need to go into the ./cache/sources/u-boot/v2019.04 folder, do a "git diff arch/arm/dts/sun8i-h3-nanopi-neo.dts > ~/git-work/igorpecovnik-armbian/build/patch/kernel/sunxi-dev/my-neo-emmc.patch" and then you can start the build !
Also, looking at your DTS attachment, you've added the network &emac, which is useless, but didn't added &mmc2, which is what you are looking for ...
added &mmc2 section into ****nanopi-neo.dts
from folder /usr/src/build/cache/sources/u-boot/v2019.04 run
"git diff arch/arm/dts/sun8i-h3-nanopi-neo.dts > /usr/src/build/patch/kernel/sunxi-dev/my-neo-emmc.patch"
from /usr/src/buid run ./compile.sh
reboot without SD - fault
BTW. ***nanopi-neo.dts hasn't &mmc2 section again. Looks like patch wasn't applied.
I've copied .diff file to the same folder as Igor's destination: ./patch/u-boot/u-boot-sunxi
and
"dd if=/tmp/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1p1 bs=1024 seek=8" (I'm not sure but I did it)
reboot without SD - SUCCESS!!!
Thank you martinayotte&Igor for your support
P.S.
last (I hope) doubt....
this command will copy a .bin file into the root folder on eMMC... how it will be read by system during the load?
no .bin files in SD-card's nor "/boot" folder nor "/ "folder
current configuration: ls /dev | grep mmcblk
mmcblk0
mmcblk0p1
mmcblk1
mmcblk1boot0
mmcblk1boot1
mmcblk1p1
No, it doesn't copy the .bin file on rootfs, but into special sector of the eMMC, the sector #16, since sectors are 512 bytes, and "bs=1024 seek=8" is equivalent of "bs=512 seek=16". It is where U-Boot is located on all AllWinner SoC.
56 minutes ago, Serge said:
please check attahed files
Thank you!
But you can also check the procedure of submitting a patch directly to the build script. It's should be simple. Try.
let me some time for cooling down. there are many steps have been taken for the first time and need to be realized
"directly to the build sript" - with "config-default.conf"or ./lib/compilation.sh? ...OFFTOPIC: now brain braking with HW connection between Core and SFP..
Everything can be done at Github. Fork the project that you can edit it. Than add this patch with appropriate name to patch/u-boot/u-boot-sunxi and create a Pull request ... which gets merged when approved.
