BreadLee Posted July 27, 2018 Share Posted July 27, 2018 Hi, I built a fresh Armbian Image from scratch (using Armbian build system). After that I used Etcher to burn .img file to SD card. Everything works great, but U-Boot shows, that there is no environment. I used saveenv and fixed a problem. Then I installed Armbian into internal memory (eMMC), same message about environment, I tried fix it same way, using saveenv, but I get only an error message and infinite loop. Screenshot attached. How I can fix that? UPD: My board - Orange Pi Zero Plus 2 Kind regards Link to comment Share on other sites More sharing options...
Igor Posted July 27, 2018 Share Posted July 27, 2018 41 minutes ago, BreadLee said: I built a fresh Armbian Image from scratch ... which uses new u-boot 2018.06 where boot environment is/must be saved to a file system. I think the location of env file is hard encoded ... well, you find a bug. If you have time, check if https://github.com/armbian/build/blob/master/lib/compilation.sh#L157 changing to CONFIG_ENV_EXT4_DEVICE_AND_PART="auto:auto" helps. Link to comment Share on other sites More sharing options...
BreadLee Posted July 27, 2018 Author Share Posted July 27, 2018 1 hour ago, Igor said: ... which uses new u-boot 2018.06 where boot environment is/must be saved to a file system. I think the location of env file is hard encoded ... well, you find a bug. If you have time, check if https://github.com/armbian/build/blob/master/lib/compilation.sh#L157 changing to CONFIG_ENV_EXT4_DEVICE_AND_PART="auto:auto" helps. Igor, thank you for your reply. I will check it right now. Link to comment Share on other sites More sharing options...
BreadLee Posted July 27, 2018 Author Share Posted July 27, 2018 2 hours ago, Igor said: If you have time, check if https://github.com/armbian/build/blob/master/lib/compilation.sh#L157 changing to CONFIG_ENV_EXT4_DEVICE_AND_PART="auto:auto" helps. Igor, I tried to do that, but currently it shows me an error with SD card also. I will try to move it on to eMMC, but it will not work, in my opinion. Update: Same with eMMC Link to comment Share on other sites More sharing options...
zador.blood.stained Posted July 27, 2018 Share Posted July 27, 2018 4 hours ago, Igor said: CONFIG_ENV_EXT4_DEVICE_AND_PART="auto:auto" "auto" is not implemented for the device identifier, only for the partition number. Though in theory it is possible to use (sunxi specific) boot device ID from the SPL header, but unless someone writes and tests this we are stuck with fixed device IDs. Link to comment Share on other sites More sharing options...
BreadLee Posted July 30, 2018 Author Share Posted July 30, 2018 On 7/27/2018 at 8:40 PM, zador.blood.stained said: Though in theory it is possible to use (sunxi specific) boot device ID from the SPL header May you tell more about your idea? Link to comment Share on other sites More sharing options...
