Ahmet Emin Koçal Posted August 1, 2018 Share Posted August 1, 2018 Hi, I have a Opi+2 board which has an Armbian system installed in its emmc. Now I want to format its Emmc and reinstall Armbian but the problem is I don't have a proper SD card. So I need to do it without an SD card. I have a running system on it, so I can reach the working system. Is there a way of formating it while its running? For example a command does the same thing with "dd if=armbian.img of="/dev/mmcblk1"" (which won't work while there is a system working, its just an example) (mmcblk1 = working system, emmc) Link to comment Share on other sites More sharing options...
tkaiser Posted August 1, 2018 Share Posted August 1, 2018 11 minutes ago, Ahmet Emin Koçal said: So I need to do it without an SD card Only way is via USB and FEL mode: https://github.com/zador-blood-stained/fel-mass-storage 1 Link to comment Share on other sites More sharing options...
Ahmet Emin Koçal Posted August 1, 2018 Author Share Posted August 1, 2018 2 minutes ago, tkaiser said: Only way is via USB and FEL mode: https://github.com/zador-blood-stained/fel-mass-storage This is almost exacly what I was looking for a few minutes ago, thank you so much! Link to comment Share on other sites More sharing options...
Ahmet Emin Koçal Posted August 1, 2018 Author Share Posted August 1, 2018 20 minutes ago, tkaiser said: Only way is via USB and FEL mode: https://github.com/zador-blood-stained/fel-mass-storage But how can I boot it in fel mode and write the armbian image? I couldn't find anything related to them Link to comment Share on other sites More sharing options...
Ahmet Emin Koçal Posted August 1, 2018 Author Share Posted August 1, 2018 24 minutes ago, tkaiser said: Only way is via USB and FEL mode: https://github.com/zador-blood-stained/fel-mass-storage I did it thank you! BTW İt feels amazing to format it without an sd card Link to comment Share on other sites More sharing options...
