Ahmet Emin Koçal Posted August 1, 2018 Share Posted August 1, 2018 I've formatted the opi+2 card I have using recovery and now I get ping screen. I use a 1280x1024 screen with a DVI converter. I tried the HDMI cable using a 1080p TV and it worked without issues. I also tried "h3disp -m 33 -d" "h3dsip -m 1024x768 -d" "h3disp -m 33" and so on. None of them worked. Here is a system output (used armbianmonitor -u) http://ix.io/1iWN !! I noticed this output when used dmesg command: [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536 Link to comment Share on other sites More sharing options...
Ahmet Emin Koçal Posted August 1, 2018 Author Share Posted August 1, 2018 I will try to move to the debian based version and tell you what happens Link to comment Share on other sites More sharing options...
Ahmet Emin Koçal Posted August 1, 2018 Author Share Posted August 1, 2018 Debian Next Image works nicely BUT I need a desktop and I can't see "Install Desktop" section on the armbian-config. And you need to fix the mainline kernel bug. EDIT Upgraded the system, and now I can see "Install Desktop" option. Thanks goes to you! Link to comment Share on other sites More sharing options...
