d7panic Posted August 5, 2018 Share Posted August 5, 2018 First : i downloaded both Armbian versions for "Orange Pi+ 2" but reported link file names where different from those that actually download : a) link says https://dl.armbian.com/orangepiplus/Ubuntu_xenial_default_desktop.7z, but download file is Armbian_5.38_Orangepiplus_Ubuntu_xenial_default_3.4.113_desktop.7z b) 2nd link says https://dl.armbian.com/orangepiplus/Debian_stretch_next.7z, but download is Armbian_5.38_Orangepiplus_Debian_stretch_next_4.14.14.7z Second : after download i extracted both with : 7z e filename.7z then i run etcher 1.4.4 cli : ./etcher -d /dev/sdd filename.img -y , result sdcard writed, then i inserted sdcard and boot it . I never had a hdmi signal and green led still blinking in both images i tried . Thanks in advance for any help Panos Link to comment Share on other sites More sharing options...
guidol Posted August 5, 2018 Share Posted August 5, 2018 The first filename is only link to the latest file which would be downloaded. The blinking Led is a sign for the heartbeat of the OS. Try to connect via Ethernet/SSH when you didnt get a HDMİ Signal. Link to comment Share on other sites More sharing options...
d7panic Posted August 5, 2018 Author Share Posted August 5, 2018 Thank you for your answer, but the lights of ethernet are not blinking so i thing that the system is not booted and maybe have wrong images . Also by searching any new ip there is no any . My board have h3 processor is possible to use images of zeroplus2-h3 ? Panos Link to comment Share on other sites More sharing options...
guidol Posted August 6, 2018 Share Posted August 6, 2018 15 hours ago, d7panic said: Thank you for your answer, but the lights of ethernet are not blinking so i thing that the system is not booted and maybe have wrong images . Also by searching any new ip there is no any . In the last months I tested some images for different boards and some did have some problem with the ethernet. Sometimes I could use a USB-Ethernet-Dingle and sometimes it only worked from the serial-Console-port or I could configure the ethernet-port from there (when the USB-Ethernet-dongle was activated) Link to comment Share on other sites More sharing options...
