xenpac Posted August 17, 2018 Share Posted August 17, 2018 i worked on the BPI M1 Board (the first one) for quite a while now improving or more or less rewriting the A20 CSI camera driver. there are no more artifact-ghost-frames any more. The framerate goes from 5fps(full) to 120fps(crobbed small) i also modified the camera-device driver for the ov5640. disadvantage: existing camera device drivers would not be compatible any more. maybe someone wants to give it a try and check it out. it can be found here: https://github.com/xenpac/OV5640-Sunxi-A20 1 Link to comment Share on other sites More sharing options...
@lex Posted August 17, 2018 Share Posted August 17, 2018 I would suggest you work on the legacy kernel 3.4.112 , that would be a boost. Any plans on that? Link to comment Share on other sites More sharing options...
xenpac Posted August 17, 2018 Author Share Posted August 17, 2018 Hi ?Alex Yes, kernel version is 3.4.112, i guess (not having it on desk) actual source code was: https://github.com/LeMaker/linux-sunxi It seems the CSI driver did not change over the last years. If u check it out, disable the DEBUG output in the source files (forgot that) addendum: the device driver files are all for ov5640, but different setups: - ov5640.c = standard the others have features like autofocus, crobbing, scaling. so just to be be able to easy switch to explore features. In ..docu/ there is a util "vt" to measure framerate with no output and also set resolutions. Link to comment Share on other sites More sharing options...
xenpac Posted August 25, 2018 Author Share Posted August 25, 2018 Just as a thought....if to integrate that into mainline..... is there any CSI support in mainline? (if not, we put it right into the Cam driver. as no one else is using CSI-0 and 1). plus supporting videobuf2. I think the Clock module is there as well as the I2C. ps. just wonder what other chips have compatible CSI port ??? Link to comment Share on other sites More sharing options...
jiapei100 Posted September 6, 2018 Share Posted September 6, 2018 Hi, xenpac: I wonder if you have a manual on how to build your driver at https://github.com/xenpac/OV5640-Sunxi-A20 ? And, how can I compile your driver with the installed linux kernel, which is also successfully booted? Cheers Pei Link to comment Share on other sites More sharing options...
xenpac Posted September 12, 2018 Author Share Posted September 12, 2018 Hi jiapei100, yes i should have named it "sun4i_csi" so one can easier clone it under .../drivers/media/video/sun4i_sci... and yes you shall have an allwinner/lemaker based kernel sourcecode on your Bananapi with its uImage being booted. Last week i checked this one and it works: https://github.com/nisenbeck/linux-bananapi unfortunate i found no armbian kernel on github, but this works with patches only i guess. Under /lib/modules/.. you find the module tree for each kernel that ever resided on your system. So..install: goto cd .../drivers/media/video/ , rm -r sun4i_csi to remove the whole driver. git clone https://github.com/xenpac/OV5640-Sunxi-A20.git now u have this "ov5640-sunxi-a20" directory under video. rename it: mv ov5640-sunxi-a20 sun4i_csi goback to your source root: make modules make modules_install reboot if you specified ov5640 as default camera in your fex file you are all set, else you have to modprobe the right one. i used "guvcview" app for testing which worked fair, cheese did not. another good test app is "qv4l2", apt-get install qv4l2 ! though video output is slow but controls work exact. in the "docu" directory there are some scripts to easy change your camera device and also a "vt" commandline tool that also outputs video. the other camera drivers in "device" are all ov5640 with some different setups, read first line in file. i will update some changes shortly. Link to comment Share on other sites More sharing options...
