rufik Posted August 18, 2018 Share Posted August 18, 2018 I'd like to migrate from SD card Samsung Evo+ to something more durable (I'm running home assistant automation on OPI PC now, mariadb, influx, etc, many writes per minute).I think that I have only two options: go with SBC with EMMC or just buy cheap 32/64 GB SSD with USB adapter. What do you think, which option gives me better durability? Can I assume that EMMC is really durable comparing to SD card?Is USB 2.0 adapter as fast as EMMC? Link to comment Share on other sites More sharing options...
hjc Posted August 18, 2018 Share Posted August 18, 2018 47 minutes ago, rufik said: mariadb, influx, etc, many writes per minute Definitely needs a SSD, not over USB 2.0, but something more reliable like the SATA on ESPRESSObin or NanoPC T4's M.2 Link to comment Share on other sites More sharing options...
rufik Posted August 18, 2018 Author Share Posted August 18, 2018 Anyone made random IO benchmarks comparing USB 2.0 and 3.0 adapter? Maybe these 100-200 SQL queries per minute does not require supa-speed? I don't think I need native M.2 slot that costs me $110. I'd like to stick with $50 tag price... Link to comment Share on other sites More sharing options...
tkaiser Posted August 18, 2018 Share Posted August 18, 2018 4 hours ago, rufik said: Anyone made random IO benchmarks comparing USB 2.0 and 3.0 adapter? Sure: Cheap SSDs are the same crap as cheap eMMC. If you care about your data you need SSDs that expose their health via SMART (so don't buy cheap SSD crap but only from those vendors providing a SMART attribute you can use as wear out indicator). I would choose an JMS578 thingy combined with a good SSD (be it mSATA, M.2 or normal SATA). More info: https://forum.openmediavault.org/index.php/Thread/23724-Run-OS-and-database-on-SD-card-to-prevent-HDD-spin-up/ Link to comment Share on other sites More sharing options...
rufik Posted August 19, 2018 Author Share Posted August 19, 2018 So SSD with SMART + JMS578 adapter is going to be the best choice. I could use it with OPI PC right now and easily migrate to USB 3.0 when needed.What about splitting rootfs into read-only SD card and all data & logs into SSD? It should give me long life of SD card and fast storage capabilites...does it make sense? Is anyone already using such setup or? Link to comment Share on other sites More sharing options...
hjc Posted August 19, 2018 Share Posted August 19, 2018 31 minutes ago, rufik said: So SSD with SMART + JMS578 adapter is going to be the best choice. I could use it with OPI PC right now and easily migrate to USB 3.0 when needed. What about splitting rootfs into read-only SD card and all data & logs into SSD? It should give me long life of SD card and fast storage capabilites...does it make sense? Is anyone already using such setup or? It's possible to use nand-sata-install to copy your rootfs to the SSD, and only leave u-boot stuff on the sd card Link to comment Share on other sites More sharing options...
