Can netconsole be enabled for S905x
I know that the RaspberryPi cannot use netconsole due to the ethernet connector being driven over the USB bus, and thus not suporting polling (which is needed for netconsole).
When i look at my LePotato kernel (4.14.57), I see:
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
So it is clear netconsole won't work as is.  Before I go through the process of building the kernel to enable these, I thought I'd check if I am wasting my time.  Is it expected that polling will work?  I don't know anything about the 'dwmac_meson8b' driver and what its capabilities might be...
Thanks.
I see it here:
drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
whch is the same directory that dwmac-meson8b.c and if I'm reading the Makefile right,  it looks like that may be included in the meson8b driver.  I guess that is enough for me to go ahead and try the build and see how it goes.
So after rebuilding the kernel with:
CONFIG_NETCONSOLE=m
CONFIG_NETCONSOLE_DYNAMIC=y
I can confirm that netconsole does indeed work properly on my 'le potato'.  Is there a process to request that this config option be included in the default Armbian builds?  It will be annoying to need to rebuild my kernel manually forever more.
Edit: I opened a request since it seems kernel config changes are appropriate here: https://github.com/armbian/build/issues/1086
