after update rpimonitor, can't monitor temp,mem,
cond080
hello there!
after update rpimonitor to 2.13-beta6 by Xavier Berger, can't monitor, any temperature , memory usage.
But CPU freq, Sd card and network work OK.
my spec : Orange pi pc +   ARMBIAN 5.38 stable Ubuntu 16.04.5 LTS 3.4.113-sun8i
error output:
sudo dpkg -i rpimonitor_2.12-r0_all.deb
Selecting previously unselected package rpimonitor.
(Reading database ... 74105 files and directories currently installed.)
Preparing to unpack rpimonitor_2.12-r0_all.deb ...
Unpacking rpimonitor (2.12-r0) ...
dpkg: dependency problems prevent configuration of rpimonitor:
 rpimonitor depends on librrds-perl; however:
  Package librrds-perl is not installed.
 rpimonitor depends on libhttp-daemon-perl (>= 6.0.0) | libwww-perl (<< 6.0.0); however:
  Package libhttp-daemon-perl is not installed.
  Package libwww-perl is not installed.
 rpimonitor depends on libjson-perl; however:
  Package libjson-perl is not installed.
 rpimonitor depends on libipc-sharelite-perl; however:
  Package libipc-sharelite-perl is not installed.
 rpimonitor depends on libfile-which-perl; however:
  Package libfile-which-perl is not installed.
dpkg: error processing package rpimonitor (--install):
 dependency problems - leaving unconfigured
Processing triggers for systemd (229-4ubuntu21.4) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for man-db (2.7.5-1) ...
Errors were encountered while processing:
 rpimonitor
6 minutes ago, Goerlitzer said:
The same with NanoPi neo. After upgrade no temperature. After I installed the rpimonitor (2.12-r0) version, no data is shown.
2.13-beta6 version was removed from the repository. That's all that can be done.
