Launch cam500a camera by nanopi neo air [solved]
amin
hi
I am grateful for the help that will be given to me.
Please help me with the launch of the cam500a by Nano Air.
I tried to use http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO_Air#Connect_to_DVP_Camera_CAM500B guides and go along with it.
but I did not succeed .
I am very beginner and need help.
This is all that I get by following the guide http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO_Air#Connect_to_DVP_Camera_CAM500B.
root@NanoPi-NEO-Air:~# cd /root/mjpg-streamer
root@NanoPi-NEO-Air:~/mjpg-streamer# make
make: svnversion: Command not found
make: Warning: File 'Makefile' has modification time 427105 s in the future
gcc -D'SVN_REV=""' -O2 -DLINUX -D_GNU_SOURCE -Wall    -c -o mjpg_streamer.o mjpg_streamer.c
gcc -D'SVN_REV=""' -O2 -DLINUX -D_GNU_SOURCE -Wall    -c -o utils.o utils.c
gcc -D'SVN_REV=""' -O2 -DLINUX -D_GNU_SOURCE -Wall  mjpg_streamer.o utils.o -lpthread -ldl -o mjpg_streamer
chmod 755 mjpg_streamer
make -C plugins/input_uvc all
make[1]: Entering directory '/root/mjpg-streamer/plugins/input_uvc'
make[1]: Warning: File 'Makefile' has modification time 427103 s in the future
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o v4l2uvc.lo v4l2uvc.c
v4l2uvc.c: In function init_videoIn’:
v4l2uvc.c:88:23: warning: variable currentHeight set but not used [-Wunused-but-set-variable]
     int currentWidth, currentHeight = 0;
v4l2uvc.c:88:9: warning: variable currentWidth set but not used [-Wunused-but-set-variable]
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o jpeg_utils.lo jpeg_utils.c
jpeg_utils.c: In function compress_yuv_to_jpeg’:
jpeg_utils.c:208:27: warning: v may be used uninitialized in this function [-Wmaybe-uninitialized]
             r = (y + (359 * v)) >> 8;
jpeg_utils.c:209:26: warning: u may be used uninitialized in this function [-Wmaybe-uninitialized]
             g = (y - (88 * u) - (183 * v)) >> 8;
jpeg_utils.c:209:20: warning: y may be used uninitialized in this function [-Wmaybe-uninitialized]
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o dynctrl.lo dynctrl.c
gcc -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o input_uvc.so input_uvc.c v4l2uvc.lo jpeg_utils.lo dynctrl.lo -ljpeg
make[1]: warning:  Clock skew detected.  Your build may be incomplete.
make[1]: Leaving directory '/root/mjpg-streamer/plugins/input_uvc'
cp plugins/input_uvc/input_uvc.so .
make -C plugins/output_file all
make[1]: Entering directory '/root/mjpg-streamer/plugins/output_file'
make[1]: Warning: File 'Makefile' has modification time 427099 s in the future
gcc -O2 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o output_file.so output_file.c
make[1]: Leaving directory '/root/mjpg-streamer/plugins/output_file'
cp plugins/output_file/output_file.so .
make -C plugins/output_udp all
make[1]: Entering directory '/root/mjpg-streamer/plugins/output_udp'
make[1]: Warning: File 'Makefile' has modification time 427098 s in the future
gcc -O2 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o output_udp.so output_udp.c
make[1]: Leaving directory '/root/mjpg-streamer/plugins/output_udp'
cp plugins/output_udp/output_udp.so .
make -C plugins/output_http all
make[1]: Entering directory '/root/mjpg-streamer/plugins/output_http'
make[1]: Warning: File 'Makefile' has modification time 427097 s in the future
gcc -c -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o httpd.lo httpd.c
gcc -O1 -DLINUX -D_GNU_SOURCE -Wall -shared -fPIC -o output_http.so output_http.c httpd.lo
make[1]: Leaving directory '/root/mjpg-streamer/plugins/output_http'
cp plugins/output_http/output_http.so .
make -C plugins/input_file all
make[1]: Entering directory '/root/mjpg-streamer/plugins/input_file'
make[1]: Warning: File 'Makefile' has modification time 427094 s in the future
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/root/mjpg-streamer/plugins/input_file'
cp plugins/input_file/input_file.so .
make: warning:  Clock skew detected.  Your build may be incomplete.
root@NanoPi-NEO-Air:~/mjpg-streamer# ./start.sh
MJPG Streamer Version: svn rev:
 i: Using V4L2 device.: /dev/video0
 i: Desired Resolution: 1280 x 720
 i: Frames Per Second.: 30
 i: Format............: YUV
 i: JPEG Quality......: 90
ERROR opening V4L interface: No such file or directory
 Init v4L2 failed !! exit fatal
 i: init_VideoIn failed
What should i do
  • Tido changed the title to Launch cam500a camera by nanopi neo air [solved]
1 hour ago, @lex said:
Here you have it:
Is cam500a the only problem? Is the problem resolved by changing it to cam500b?
There is no way to answer the cam500a?
Thank you very much for your directions
CAM500A needs to add some resistor to work with neo air.
There was an instruction on FriendlyArm  to add this resistor to become CAM500B, but i can't find it right now.
I also feel there is another problem, I do not understand it
When I execute command ''make'' , the operation is not successful
Can you guide me where the problem is?
