deeagle Posted September 10, 2018 Share Posted September 10, 2018 Hello fellas, I would like to borrow your experience to compete with my task which counts (and measures) pulses on GPIO with Orange Pi zero. Currently, my simple solution is to register a callback to a specific edge and increment a global variable. I would like to catch a few hundreds of pulses in one burst which have in a 5-100 us length. However, even the number of counted pulses is not okay. Some of them are missed sometimes, which leads to an unreliable solution. I used different libs and all of them fall into the same issue. I tried the following libs: * ArmbianIO (C) * ArmbianIO (Python: original API) * ArmbianIO (Python: RPi compatibility API) * OPi I have missed the pyH3 forks intentionally as they do not offer callback functionality. I see on an oscilloscope that all the pulses arrive in the GPIO pin. The signal has a nice square shape and has the good level. I tried the ArmbianIO RPi compatibility API version to run on real Raspberry, and it is reliable works there. I noticed, that when it misses some pulses, the htop shows CPU usage peek. What was visible is the network manager, so I blacklisted Wifi modul and killed the wpa agent. I only use cable. The problem still appears. I also tried to raise the nice level, but it did not help, so I am out of ideas. Could it really be CPU load problem? Or does anybody has any idea what can go wrong and how it can be fixed? Thank you in advance! My actual implementation is here: from __future__ import print_function import time from armbianio.armbianio import * import atexit DETECT_GPIO_CH = 3 active = True started = False tick_count = 0 def catch_code(): print("Waiting for code...") global started global active while not started: time.sleep(10.0e-3) time.sleep(550.0e-3) started = False active = False print("Code: {}".format(tick_count)) def edge_detected(channel): if active: global started global tick_count if not started: tick_count = 0 started = True else: tick_count += 1 def cleanup(): AIORemoveGPIOCallback(DETECT_GPIO_CH) AIOWriteGPIOEdge(DETECT_GPIO_CH, EDGE_NONE) AIOShutdown() def main(): AIOInit() AIOAddGPIO(DETECT_GPIO_CH, GPIO_IN) AIOWriteGPIOEdge(DETECT_GPIO_CH, EDGE_FALLING) time.sleep(1) AIOAddGPIOCallback(DETECT_GPIO_CH, AIOCALLBACK(edge_detected)) atexit.register(cleanup) catch_code() if __name__ == "__main__": main() Link to comment Share on other sites More sharing options...
martinayotte Posted September 10, 2018 Share Posted September 10, 2018 2 hours ago, deeagle said: one burst which have in a 5-100 ns length Are you sure about "ns" ? Because this means it is equivalent to 10Mhz to 200MHz ... Link to comment Share on other sites More sharing options...
deeagle Posted September 11, 2018 Author Share Posted September 11, 2018 18 hours ago, martinayotte said: Are you sure about "ns" ? Because this means it is equivalent to 10Mhz to 200MHz ... You are right. It is a typo. I fixed the description. Link to comment Share on other sites More sharing options...
martinayotte Posted September 11, 2018 Share Posted September 11, 2018 1 hour ago, deeagle said: You are right. It is a typo. I fixed the description. That's look more realistic ... Link to comment Share on other sites More sharing options...
