schwar3kat Posted September 14, 2018 Share Posted September 14, 2018 I'm a newb, so please make allowances if I am a little dumb. I have SPI NOR boot working on an Orange Pi Zero Plus (H5). Latest next kernel. (I've tried the download, and compiled my own). There is a problem when I power on. It fails to detect the USB drive. If I reset the CPU it finds the drive. If I reboot it finds the drive. resetting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found I want to try some things in the boot environment settings, but I haven't figured out where to do this. Can anyone point me in the right direction to modify the environment for this board? I have a Vagrant build environment set up, so I can compile, but so far I haven't been able to find where these settings are configured Link to comment Share on other sites More sharing options...
martinayotte Posted September 14, 2018 Share Posted September 14, 2018 That is probably due to the fact that your USB drive take a while to become ready... You probably need to try adding INITIAL_USB_SCAN_DELAY in u-boot config and recompile it ... https://lists.denx.de/pipermail/u-boot/2016-April/250343.html Link to comment Share on other sites More sharing options...
Solution schwar3kat Posted September 15, 2018 Author Solution Share Posted September 15, 2018 Thanks martinayotte - it is working now. I'm describing this for other newbs who might struggle to find these things. Your referenced patch has pointed me to "arch/arm/mach-sunxi/usb_phy.c" which I found in my Vagrant build environment at "/home/vagrant/armbian/cache/sources/u-boot/<version>/" The line "static int initial_usb_scan_delay = CONFIG_INITIAL_USB_SCAN_DELAY;" exists so it looks like the referenced patch is now a part of the build. I found the u-boot configs under "/home/vagrant/armbian/cache/sources/u-boot/<version>/configs" and the one for my board is named "orangepizero_plus_defconfig" cd /home/vagrant/armbian sudo nano config-default.conf modify line CREATE_PATCHES="no" to CREATE_PATCHES="yes" ^X y enter to save sudo ./compile.sh Select your board then enter at the prompts until you reach: [ warn ] Make your changes in this directory: [ /home/vagrant/armbian/cache/sources/u-boot/] [ warn ] Press <Enter> after you are done [ waiting ] In a new session - (I used putty, I couldn't do it from the windows command prompt vagrant ssh ) cd /home/vagrant/armbian/cache/sources/u-boot/<version>/configs sudo nano orangepizero_plus_defconfig add a line CONFIG_INITIAL_USB_SCAN_DELAY=3000 ^X y enter to save Back to the original session press enter and answer all prompts until compile is complete. diff --git a/configs/orangepizero_plus_defconfig b/configs/orangepizero_plus_defconfig index 4298f1e..ef14bcb 100644 --- a/configs/orangepizero_plus_defconfig +++ b/configs/orangepizero_plus_defconfig @@ -20,3 +20,4 @@ CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_SD_BOOT=y +CONFIG_INITIAL_USB_SCAN_DELAY=3000 The patch will be in \vagrant\output\patch\u-boot-sunxi64-next.patch Don't be tempted to edit this file in windows. It will be corrupted by the line feeds. Link to comment Share on other sites More sharing options...
TonyMac32 Posted September 16, 2018 Share Posted September 16, 2018 On 9/15/2018 at 2:38 AM, Elektrický said: Don't be tempted to edit this file in windows. It will be corrupted by the line feeds. * Don't use notepad to edit this file in Windows. Use Notepad++ or another adequate editor, the only ones adding linefeeds date back to MSDOS. It's not intrinsic to the operating system, it's editor-dependant. Link to comment Share on other sites More sharing options...
