Guest Posted September 30, 2018 Share Posted September 30, 2018 Hello, I'm using a BananaPi M1 board long time with armbian. Most of the other BananaPi boards are no longer supported with armbian. Which board will have the best change to armbian lts? I only need a board with 1GB RAM, 2 x USB, 1 x Gigabit Net, SATA for small home server settings. Any hint? Link to comment Share on other sites More sharing options...
chwe Posted September 30, 2018 Share Posted September 30, 2018 That's not up to armbian to decide... If the boardmaker drops a board it might get dropped by armbian earlier. 5 hours ago, RSU said: SATA be more specific here.. SATA over USB2 (e.g. max ~40mb/s) is sufficient? price range? some stuff worth to read: https://forum.armbian.com/forum/29-reviews/ Link to comment Share on other sites More sharing options...
guidol Posted September 30, 2018 Share Posted September 30, 2018 5 hours ago, RSU said: Any hint? As NAS the Hardkernel Odroid HC-1 (for 2.5") or HC-2 (for 3.5") seems to be for me a good choice at this time HC-1:https://www.hardkernel.com/main/products/prdt_info.php?g_code=G150229074080 HC-2:https://www.hardkernel.com/main/products/prdt_info.php?g_code=G151505170472 Armbian HC-1/HC-2:https://www.armbian.com/odroid-hc1/ 1 Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2018 Share Posted September 30, 2018 Hi, ok... some more information. I need SATA just for one system 2.5" hdd/ssd. It is not used for NAS, I've a NAS server already on LAN. The board is connected to WAN and there is a web server (nginex) running, and also ftp/ssh server and vpn (client to my internet server). That's all. It is my outside connection to my LAN. Link to comment Share on other sites More sharing options...
Mr.Grape Posted October 1, 2018 Share Posted October 1, 2018 14 hours ago, RSU said: Hi, ok... some more information. I need SATA just for one system 2.5" hdd/ssd. It is not used for NAS, I've a NAS server already on LAN. The board is connected to WAN and there is a web server (nginex) running, and also ftp/ssh server and vpn (client to my internet server). That's all. It is my outside connection to my LAN. Perhaps Odroid HC1 / HC2. For me, HC1 works as a mini general purpose server. Link to comment Share on other sites More sharing options...
Guest Posted October 1, 2018 Share Posted October 1, 2018 Odroid HC1 seems to be a good solution for me and makes a good impression. Thanks for the hints! Link to comment Share on other sites More sharing options...
Mr.Grape Posted October 1, 2018 Share Posted October 1, 2018 46 minutes ago, RSU said: Odroid HC1 seems to be a good solution for me and makes a good impression. Thanks for the hints! If you finally decide on HC1, make sure you are up-to-date after the purchase.... https://wiki.odroid.com/odroid-xu4/software/jms578_fw_update https://wiki.odroid.com/odroid-xu4/troubleshooting/shutdown_script Link to comment Share on other sites More sharing options...
