data Posted October 4, 2018 Share Posted October 4, 2018 Can someone recommend a good & cheap heatsink for the Lite2 from Aliexpress? Link to comment Share on other sites More sharing options...
turbopower Posted October 4, 2018 Share Posted October 4, 2018 Heatsink without fan and properly designed case is pointless.Passive small heatsink it will give you little bit more time before overheat protection to take place.The rest is marketing Sent from my D6503 using Tapatalk Link to comment Share on other sites More sharing options...
data Posted October 5, 2018 Author Share Posted October 5, 2018 So which product do you recommend? Link to comment Share on other sites More sharing options...
turbopower Posted October 5, 2018 Share Posted October 5, 2018 Take a standard case and modify it to fit fan and have enough holes for airflow. The best way to cool it down is to suck the air our. Don't mount any heatsink at the beginning, just fan and check the temperature. If is under 80 degrees Celsius then everything is fine. Link to comment Share on other sites More sharing options...
may Posted October 6, 2018 Share Posted October 6, 2018 I bought a large heatsink size 37*37*24mm and modified with my dremel. And then connect the heatsink and the soc with a pice of copper and 3M™ Thermally Conductive Adhesive Transfer Tape 8810. I've learned that both the ap6255 module and the ddr ram onboard generates lots of heat. ap6255 gets overheat under heavy load and stop working until core temperature drops under alert temperature without a proper heatsink this brand is called "Your Cee" on aliexpress 1 Link to comment Share on other sites More sharing options...
