aliceander Posted October 6, 2018 Share Posted October 6, 2018 I'm having trouble porting some WiringPi programs to my NanoPi Neo. I have an original neo v1.0 running the latest armbian stretch (as of Oct 04 2018). Have tried several, including mstroh76/WiringNP, and can compile, but programs hang when executed. I'm okay if this is the deep-end of the pool but I wanted to verify that I an indeed in deep waters or if I'm doing something dumb and really in the shallow waters and all I have to do is stand up to get my head out of the water. Which WiringPi library should I be using for C language programs on a NanoPi NEO v1.0 running a recent Armbina Stretch release? Link to comment Share on other sites More sharing options...
nopnop2002 Posted October 9, 2018 Share Posted October 9, 2018 Try this https://github.com/wertyzp/WiringNP It's my environment $ cat /etc/os-release PRETTY_NAME="Debian GNU/Linux 9 (stretch)" NAME="Debian GNU/Linux" VERSION_ID="9" VERSION="9 (stretch)" ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" $ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=nanopineo BOARD_NAME="NanoPi Neo" BOARDFAMILY=sun8i VERSION=5.60 LINUXFAMILY=sunxi BRANCH=next ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage Link to comment Share on other sites More sharing options...
Tido Posted October 9, 2018 Share Posted October 9, 2018 for C ArmbianIO https://forum.armbian.com/topic/5655-armbianio-api-proposal/ this one, User Space IO is Python 3 and Java 8 bindings for user space GPIO, SPI, I2C, PWM and Serial interfaces https://forum.armbian.com/topic/6523-user-space-io-is-python-3-and-java-8-bindings-for-user-space-gpio-spi-i2c-pwm-and-serial-interfaces/ Link to comment Share on other sites More sharing options...
aliceander Posted October 9, 2018 Author Share Posted October 9, 2018 WiringNP looks like it should work; compiles and installs, gpio readall run ok, and I can compile apps including the library. The problem may be with the app. I'm running https://github.com/bigjosh/NeoUart with one neopixel with connections [GND pin 6,VDD pin 1, DIN pin 8 (GPIO 14, TX UART), DOUT unconnected]. Runs ok on a raspi model b+, but when I run on a neopi neo it spins a processor at %100 and hangs. I remember that orange pi's had their pin orientation rotated oddly (180), so I verified the pinout, but the neo seems to follow expected orientation. My armbian-release and os-release are the same as @nopnop2002. I'll review @Tido's suggestion this morning. Link to comment Share on other sites More sharing options...
nopnop2002 Posted October 10, 2018 Share Posted October 10, 2018 22 hours ago, aliceander said: I'm running https://github.com/bigjosh/NeoUart with one neopixel with connections [GND pin 6,VDD pin 1, DIN pin 8 (GPIO 14, TX UART), DOUT unconnected]. Without using WiringPi, address operation of gpio is being performed directly, so NeoUart doesn't work with Opi. I have not tried, but you can probably use this. https://github.com/vanvught/rpidmx512/tree/master/lib-ws28xx Link to comment Share on other sites More sharing options...
