Update uboot is invalid
nasbdh9
I purchased a V7 version of ebin
But after updating uboot, the reboot is still in stock uboot.
Marvell>> bubt flash-image-1g-1cs-1000_800.bin spi usb
Burning U-BOOT image "flash-image-1g-1cs-1000_800.bin" from "usb" to "spi"
USB0:   Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 2 USB Device(s) found
reading flash-image-1g-1cs-1000_800.bin
Image checksum...OK!
SF: Detected mx25u3235f with page size 256 Bytes, erase size 64 KiB, total 4 MiB
262144 bytes written, 593344 bytes skipped in 2.65s, speed 424017 B/s
Done!
Marvell>> TIM-1.0
TIM-1.0
TIM-1.0
WTMI-armada-17.10.5-bb8f823
WTMI: system early-init
SVC REV: 4, CPU VDD voltage: 1.120V
Fill memory before self refresh...done
Now in Self-refresh Mode
Exited self-refresh ...
Self refresh Pass.
DDR self test mode test done!!
Vref read training
Final vdac_value 0x00000020
Vref write training
Final vref_value 0x0000001F
DLL TUNING
   DLL 0xc0001050[21:16]: [8,35,1e]
   DLL 0xc0001050[29:24]: [8,2b,19]
   DLL 0xc0001054[21:16]: [b,31,1e]
   DLL 0xc0001054[29:24]: [e,30,1f]
   DLL 0xc0001074[21:16]: [0,3f,1f]
   DLL 0xc0001074NOTICE:  Booting Trusted Firmware
NOTICE:  BL1: v1.3(release):armada-17.10.3:39a62a1
NOTICE:  BL1: Built : 15:40:57, Jun  1 2NOTICE:  BL2: v1.3(release):armada-17.10.3:39a62a1
NOTICE:  BL2: Built : 15:40:59, Jun  1 201NOTICE:  BL31: v1.3(release):armada-17.10.3:39a62a1
NOTICE:  BL31:
U-Boot 2017.03-armada-17.10.2-g14aeedc (Jun 01 2018 - 15:39:10 +0800)
Model: Marvell Armada 3720 Community Board ESPRESSOBin
       CPU    @ 1000 [MHz]
       L2     @ 800 [MHz]
       TClock @ 200 [MHz]
       DDR    @ 800 [MHz]
DRAM:  1 GiB
U-Boot DT blob at : 000000003f7161b8
Comphy-0: USB3          5 Gbps
Comphy-1: PEX0          2.5 Gbps
Your u-boot was not provided by Armbian - you can convince yourself by comparing it to the ones in the Archive (yours was compiled on June 1st, in timezone GMT +8 ...).
Your EspressoBin is equipped with a Macronix SPI - if you need to rescue it start from here or here.
22 minutes ago, Igor said:
Last u-boot builds should have support for Macronix OOTB, right?
That's what I tested, but to be completely sure I'll check the test logs I published in the other thread to make sure the printed build date got updated.
If the flashed file turns out to be Armbian's, my only theory is that the factory bootloader recognises the Macronix chip but somehow fails to update its contents (so that the factory bootloader remains unchanged).
That could be fixed by reflashing from an UART-downloaded image.
Yeah, I also got versions/dates like the ones here after I successfully flashed via UART download + bubt:
TIM-1.0
WTMI-devel-18.07.0-6050fd5
SVC REV: 5, CPU VDD voltage: 1.155V
NOTICE:  BL1: v1.5(release):711ecd3 (Marvell-armada-18.09.4)
NOTICE:  BL1: Built : 15:13:47, Sep  7 2018
NOTICE:  BL1: Booting BL2
NOTICE:  BL2: v1.5(release):711ecd3 (Marvell-armada-18.09.4)
NOTICE:  BL2: Built : 15:13:50, Sep  7 2018
NOTICE:  BL1: Booting BL31
NOTICE:  BL31: v1.5(release):711ecd3 (Marvell-armada-18.09.4)
NOTICE:  BL31: Built : 15:1
U-Boot 2017.03-armada-18.09.1-ga92bd86-armbian (Sep 05 2018 - 21:49:34 +0200)
       CPU     1000 [MHz]
       L2      1000 [MHz]
       NB AXI  250 [MHz]
       SB AXI  250 [MHz]
       DDR     800 [MHz]
DRAM:  2 GiB
U-Boot DT blob at : 000000007f7142d8
Comphy chip #0:
Comphy-2: SATA0         6 Gbps
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq led only pmp fbss pio slum part sxs
PCIE-0: Link up
MMC:   sdhci@d0000: 0
Net:   eth0: neta@30000 [PRIME]
Hit any key to stop autoboot:  0
Marvell>>
There are some nice upgrades in this v7 board design, like the new SATA connector. However the FW image is based on old Marvell 17.10 LSP. Since the new DDR4 layout is only included in Globalscale in-house FW images, the official Marvell LSP has no support for the new DDDR4 layouts yet. Marvell asked Globalscale team to upgrade their base to 18.09. If it happens, it will be much easier to add these new layouts to the official LSP and to the mainline sources.
FYI - the A3700 support pull request is under review @ TF-A right now. Once it gets merged, you will be able to try the new TF-A v2.0. Unfortunately this PR code supports only DDR3-based EspressoBin for now.
GlobalScale has published some stuff for the V7 EspressoBin here and here (based on the version 17.x bootloader). May be that is useful for you.
Armbian uses the 18.x branch of the bootloader and the environment settings are adapted to it.
Updated sources of the 18.x bootloader with support for the V7 EspressoBin are expected to be published by Marvell some time soon and updated versions of Armbian and the corresponding bootloader images for V7 EspressoBins will follow.
