Syed Idris S B Posted October 24, 2018 Share Posted October 24, 2018 The current image for OrangePiLite2 Armbian Bionic/Stretch not booting I tried, Armbian_5.64.181019_Orangepilite2_Ubuntu_bionic_dev_4.18.15 and Armbian_5.64.181023_Orangepilite2_Debian_stretch_dev_4.18.16. When connected to HDMI monitor, I just a red light up and nothing else. However, this version of image works, Armbian_5.59.180824_Orangepilite2_Debian_stretch_dev_4.18.0-rc7 Link to comment Share on other sites More sharing options...
Igor Posted October 25, 2018 Share Posted October 25, 2018 Both works. Just HDMI is temporally broken. And this is not a problem since H6 support is still in development and will remain there for several months. Link to comment Share on other sites More sharing options...
gyrex Posted November 4, 2018 Share Posted November 4, 2018 I, too, am having issues with the latest builds. HDMI isn't working, but the board doesn't appear to be populating a serial port via micro USB for initial configuration. Is there some alternative way of configuring the board without HDMI and without a virtual serial port? Link to comment Share on other sites More sharing options...
Igor Posted November 4, 2018 Share Posted November 4, 2018 2 hours ago, gyrex said: Is there some alternative way of configuring the board without HDMI and without a virtual serial port? Via normal 3 wire serial port? MicroUSB serial console is enabled on H3/H5 stable builds, while here (development builds) you have to do make it if you want to use it. Link to comment Share on other sites More sharing options...
gyrex Posted November 4, 2018 Share Posted November 4, 2018 4 hours ago, Igor said: Via normal 3 wire serial port? MicroUSB serial console is enabled on H3/H5 stable builds, while here (development builds) you have to do make it if you want to use it. OK, no problems, thanks Igor Link to comment Share on other sites More sharing options...
AndreBotelho Posted November 6, 2018 Share Posted November 6, 2018 On 10/25/2018 at 2:02 AM, Igor said: Both works. Just HDMI is temporally broken. And this is not a problem since H6 support is still in development and will remain there for several months. I've bought a OPI Lite 2 and want to develop on it, if it works but without video, what option do I have to login? Is there a way I can fix de HDMI driver on the source knowing what have you changed that break it? Link to comment Share on other sites More sharing options...
Igor Posted November 6, 2018 Share Posted November 6, 2018 6 minutes ago, AndreBotelho said: I've bought a OPI Lite 2 and want to develop on it, if it works but without video, what option do I have to login? Is there a way I can fix de HDMI driver on the source knowing what have you changed that break it? It will probably be fixed when we bump kernel to 4.19.y I fix things which I know where to fix them and if I have time for that. If you want to help, do something simple first: https://www.armbian.com/get-involved 6 minutes ago, AndreBotelho said: what option do I have to login? Serial console. Link to comment Share on other sites More sharing options...
AndreBotelho Posted November 6, 2018 Share Posted November 6, 2018 8 minutes ago, Igor said: It will probably be fixed when we bump kernel to 4.19.y I fix things which I know where to fix them and if I have time for that. If you want to help, do something simple first: https://www.armbian.com/get-involved Serial console. Serial in what connection, it works through micro USB? Link to comment Share on other sites More sharing options...
Igor Posted November 6, 2018 Share Posted November 6, 2018 22 minutes ago, AndreBotelho said: Serial in what connection, it works through micro USB? Read this topic. Link to comment Share on other sites More sharing options...
martinayotte Posted November 6, 2018 Share Posted November 6, 2018 47 minutes ago, AndreBotelho said: Serial in what connection There is a 3 pins Serial Debug header on every OrangePi boards. Simply hookup USB-TTL-Serial dongle on this header, those dongles are cheap, usually around $1 ... (I've around 10 of them in my lab) Link to comment Share on other sites More sharing options...
AndreBotelho Posted November 7, 2018 Share Posted November 7, 2018 On 11/6/2018 at 12:30 PM, martinayotte said: There is a 3 pins Serial Debug header on every OrangePi boards. Simply hookup USB-TTL-Serial dongle on this header, those dongles are cheap, usually around $1 ... (I've around 10 of them in my lab) Thanks, I'll try to find one to buy, need another card to use with armbian too because I'm playing with Ubuntu version from orange pi site. Link to comment Share on other sites More sharing options...
