OMV Broken package ?
pidou46
Hello,
From a fresh new install (after upgrade), I try to install OpenMediaVault + OwnCloud using armbian-config, it leads to apt's lock out.:
I have proceed, another time, and it leads to the same result.
The troublesome package seems to be "openmediavault-omvextrasorg":
"Removing openmediavault-omvextrasorg (4.1.11) ...
/var/lib/dpkg/info/openmediavault-omvextrasorg.postrm: 22: .: Can't open /usr/share/openmediavault/scripts/helper-functions
dpkg: error processing package openmediavault-omvextrasorg (--remove):
 subprocess installed post-removal script returned error exit status 2
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)"
Any workaround ?
Thanks
Thanks for your answer Igor.
Sorry I would say NextCloud instead of OwnCloud (I came from OwnCloud and have not completed the naming switch in my brain)
Should I install OMV from armbian-config and then NextCloud manualy ?
No, you have to pick one of. Both suits the same purpose as @Tido pointed out and use the same low level services.
  • Igor locked this topic
On 10/27/2018 at 5:06 PM, pidou46 said:
I definitely don't need both, I just try to install NC from armbian-config and it broke OpenMediaVault (see error message in my first post)
  • Igor unlocked this topic
