lemonahmas Posted November 3, 2018 Share Posted November 3, 2018 As the link below. http://rover.ebay.com/rover/1/710-53481-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=382617850793&ipn=psmain&icep_vectorid=229508&kwid=902099&mtid=824&kw=lg&toolid=11111 Link to comment Share on other sites More sharing options...
usuario74 Posted December 5, 2018 Share Posted December 5, 2018 Is your ethernet working fine? "Important: Some devices suffer from a Gbit Ethernet issue related to the GbE PHY leading to a severe amount of packet losses which might render Ethernet unuseable. It’s confirmed as a hardware issue and if you’re affected or not can be simply checked by testing network throughput with iperf3. Against another GbE capable device, you should exceed 900 Mbits/sec with Armbian (only 800 Mbits/sec in RX direction when not using Xenial due to iperf3 being single-threaded in both directions then and bottlenecked by CPU). If you see low throughput and high retransmit counts then a workaround is to switch to Fast Ethernet only by adding ethtool -s eth0 speed 100 duplex full to /etc/rc.local" Link to comment Share on other sites More sharing options...
Igor Posted December 5, 2018 Share Posted December 5, 2018 17 minutes ago, usuario74 said: Is your ethernet working fine? It is. With recent kernel which in the development. 1 Link to comment Share on other sites More sharing options...
usuario74 Posted December 5, 2018 Share Posted December 5, 2018 1 hour ago, Igor said: It is. With recent kernel which in the development. So is not a hardware issue, then? Or maybe a work around was found. Thanks. Link to comment Share on other sites More sharing options...
margaspeak Posted December 6, 2018 Share Posted December 6, 2018 If it is working fine then why are you selling it? Also, I want to know your thoughts about the use of shock collars for dogs in eliminating its excessive barking behavior. Link to comment Share on other sites More sharing options...
Igor Posted December 6, 2018 Share Posted December 6, 2018 40 minutes ago, margaspeak said: If it is working fine then why are you selling it? With stock images it is certainly not working good. Only with latest kernel, 4.19.y, A64 boards get decent support. Link to comment Share on other sites More sharing options...
