Andy Kononov Posted November 8, 2018 Share Posted November 8, 2018 when build armbian via docker "proces will create and run a named Docker container armbian with 2 named volumes armbian-cache and armbian-ccache" and store it in /var. My root amount is not over 40Gb and it will be good thing to store armbian-cache and armbian-ccache in different place Link to comment Share on other sites More sharing options...
Igor Posted November 8, 2018 Share Posted November 8, 2018 57 minutes ago, Andy Kononov said: it will be good thing Agree. https://www.armbian.com/get-involved/ Link to comment Share on other sites More sharing options...
chrisf Posted November 8, 2018 Share Posted November 8, 2018 You could mount a different volume at the place those directories are. Might even work with a symlink Link to comment Share on other sites More sharing options...
Andy Kononov Posted November 9, 2018 Author Share Posted November 9, 2018 found solution First create directory and file for custom configuration: sudo mkdir -p /etc/systemd/system/docker.service.d sudo $EDITOR /etc/systemd/system/docker.service.d/docker-storage.conf For docker version before 17.06-ce paste: [Service] ExecStart= ExecStart=/usr/bin/docker daemon -H fd:// --graph="/mnt" For docker after 17.06-ce paste: [Service] ExecStart= ExecStart=/usr/bin/dockerd -H fd:// --data-root="/mnt" Alternative method through daemon.json I recently tried above procedure with 17.09-ce on Fedora 25 and it seem to not work. Instead of that simple modification in /etc/docker/daemon.json do the trick: { "graph": "/mnt", "storage-driver": "overlay" } Despite the method you have to reload configuration and restart Docker: sudo systemctl daemon-reload sudo systemctl restart docker To confirm that Docker was reconfigured: docker info|grep "loop file" In recent version (17.03) different command is required: docker info|grep "Docker Root Dir" Output should look like this: Data loop file: /mnt/devicemapper/devicemapper/data Metadata loop file: /mnt/devicemapper/devicemapper/metadata Or: Docker Root Dir: /mnt Then you can safely remove old Docker storage: rm -rf /var/lib/docker Link to comment Share on other sites More sharing options...
