Rolf Bakker Posted November 12, 2018 Share Posted November 12, 2018 I've got a working Vagrant Armbian Build environment. Now I want to add the following to the sun50i-h5-nanopi-neo2.dts (provides network support in U-boot) and compile a new image. &emac { pinctrl-names = "default"; pinctrl-0 = <&emac_rgmii_pins>; status = "okay"; phy = <&phy1>; phy-mode = "rgmii"; phy1: ethernet-phy@1 { reg = <0>; }; }; Despite reading the docs, I still can't figure out how it's done. Maybe someone can point me in the right direction? Link to comment Share on other sites More sharing options...
Igor Posted November 12, 2018 Share Posted November 12, 2018 build with CREATE_PATCHES="yes", edit kernel source when you are asked and use created patch (output/patch) for the future (patch/u-boot/u-boot-sunxi). You can also send the patch back to the build script that others can benefit from your work. Link to comment Share on other sites More sharing options...
Rolf Bakker Posted November 12, 2018 Author Share Posted November 12, 2018 Thank you for the swift reply! I will try this. Link to comment Share on other sites More sharing options...
Rolf Bakker Posted November 12, 2018 Author Share Posted November 12, 2018 - Link to comment Share on other sites More sharing options...
Rolf Bakker Posted January 27, 2019 Author Share Posted January 27, 2019 It has been a while but I can confirm that it works. I've seen that U-boot network support is now already included in the default Armbian. Great! Link to comment Share on other sites More sharing options...
