trohn_javolta Posted November 14, 2018 Share Posted November 14, 2018 I'm gonna keep this short. I installed Omv on my Odroid HC2 via armbian-config. I messed up and now cannot get into discs or filesystems tab in Omv and cannot add new shared folder. Using a htpc script called Atomic Toolkit, I updated an app, I think nginx and by that the PHP 7.2 automatically was installed by the script. Here is the thread on Omv. I'm writing this in the hope that maybe @tkaiser or someone else may have an idea to fix this. If not, I'll start over and would like to know how I can reinstall omv. In armbian-config I tried to untick omv and continue, but this does not remove omv ..Maybe I don't have to completely remove omv. I just want to make sure I have the "armbian omv" again. Link to comment Share on other sites More sharing options...
trohn_javolta Posted November 22, 2018 Author Share Posted November 22, 2018 Ok, it is settled, I'm gonna reinstall omv...but I don't know how to do it Maybe someone could help me? I tried to purge omv packages and reinstall it via armbian-config, which led to errors: https://github.com/armbian/config/issues/37#issuecomment-440919087 Got the info that omv install via armbian-config is only supposed to work on a clean debian install. However I don't plan on reinstalling armbian and start over again. So, how would I reinstall omv and have all the specific armbian improvements? Link to comment Share on other sites More sharing options...
Igor Posted November 22, 2018 Share Posted November 22, 2018 37 minutes ago, trohn_javolta said: However I don't plan on reinstalling armbian and start over again. So, how would I reinstall omv and have all the specific armbian improvements? Talk to OMV people to develop OMV cleaner. We will certainly not. This has nothing to do with Armbian/Debian. Use some sort of virtualization for the future to avoid such troubles. Link to comment Share on other sites More sharing options...
trohn_javolta Posted November 22, 2018 Author Share Posted November 22, 2018 26 minutes ago, Igor said: Talk to OMV people to develop OMV cleaner. We will certainly not. This has nothing to do with Armbian/Debian. Use some sort of virtualization for the future to avoid such troubles. For me it's overkill anyways. The reason I used it is because with other distros via smb I "only" got 60 mb/s transfer speed. I read the omv installed via armbian-config comes with enhancements, also in smb settings. And indeed with that I got 100 mb/s. I'd happily ditch omv if I'd know what I have to change in smb settings to get that speed. Does the samba install from armbian-config come with same enhancements?..tbh I didn't try that yet. Link to comment Share on other sites More sharing options...
trohn_javolta Posted November 26, 2018 Author Share Posted November 26, 2018 On 11/22/2018 at 2:22 PM, Igor said: Talk to OMV people to develop OMV cleaner. We will certainly not. This has nothing to do with Armbian/Debian. Use some sort of virtualization for the future to avoid such troubles. Removed omv and installed samba. As expected, now I get like 60 mb/s transfer speed. What tweaks are made to omv's samba installed via armbian-config? I copied and pasted the old smb conf, I guess there are important settings I have also set: write cache size = 524288 getwd cache = yes use sendfile = yes min receivefile size = 16384 Also I made sure samba process is running on big cores. Still only 60 mb/s. Link to comment Share on other sites More sharing options...
Igor Posted November 27, 2018 Share Posted November 27, 2018 8 hours ago, trohn_javolta said: Also I made sure samba process is running on big cores. Still only 60 mb/s. Don't know. Not my area of interest. I would need to search but you can also do that. I am pretty sure this topic was discussed. When found, you can sent changes to the armbian-config. Link to comment Share on other sites More sharing options...
