Oleksii Posted November 15, 2018 Share Posted November 15, 2018 I'm about to install active cooling fan on my recently delivered nanoPI T4. However, I cannot get what is a type of the soldered 3-pin fan connector on this board? What I see there is visually too small as for standard connector size. Is it something special I have no clue about yet, or it is for future proprietary Friendlyarm's fan designed specially for the board? Any suggestions are welcome! Thanks Link to comment Share on other sites More sharing options...
shaun27 Posted November 15, 2018 Share Posted November 15, 2018 3 hours ago, Oleksii said: I'm about to install active cooling fan on my recently delivered nanoPI T4. However, I cannot get what is a type of the soldered 3-pin fan connector on this board? What I see there is visually too small as for standard connector size. Is it something special I have no clue about yet, or it is for future proprietary Friendlyarm's fan designed specially for the board? Any suggestions are welcome! Thanks I think you would have to wire it yourself tbh. Connector wise your looking for http://www.hobbytronics.co.uk/cables-connectors/polarized-connector-housing a 3 pin one. Dont forget the crimp pins and all. Im assuming this is the right size for the pins but you will need to check the pin size. I dont have this board so cant be certain on the pin size. 1 Link to comment Share on other sites More sharing options...
Oleksii Posted November 15, 2018 Author Share Posted November 15, 2018 4 hours ago, shaun27 said: I think you would have to wire it yourself tbh. Well, I anticipated such answer just a little bit of hope there might be some ready-to-go solutions already... Thank you! Link to comment Share on other sites More sharing options...
morfane Posted November 26, 2018 Share Posted November 26, 2018 On 11/15/2018 at 7:46 PM, Oleksii said: I'm about to install active cooling fan on my recently delivered nanoPI T4. However, I cannot get what is a type of the soldered 3-pin fan connector on this board? What I see there is visually too small as for standard connector size. Is it something special I have no clue about yet, or it is for future proprietary Friendlyarm's fan designed specially for the board? Any suggestions are welcome! Thanks I have the same problem, just connected a 2 pin 5V from the casual pins instead of using the fan controller designed for the board. I Also mentioned in one of my emails to FriendlyElec with another bunch of questions, yet that question remained unanswered. If you find a fan with a connector that fits, please publish it so others like me can also use the solution. 1 Link to comment Share on other sites More sharing options...
Oleksii Posted November 27, 2018 Author Share Posted November 27, 2018 On 11/26/2018 at 4:44 AM, morfane said: I have the same problem, just connected a 2 pin 5V from the casual pins instead of using the fan controller designed for the board. I Also mentioned in one of my emails to FriendlyElec with another bunch of questions, yet that question remained unanswered. If you find a fan with a connector that fits, please publish it so others like me can also use the solution. Frankly, I wouldn't even bother myself with active cooling, because I like silent PCs more I simply underestimated this RK3399's temperament. I also purchased metal case for this model which can hardly fit standard dimensions fan and provide really efficient air-flow. Thus, I will try to improve passive cooling first of all (put some copper shim + thermal grease instead of magic blue chewing gum e.g.). Then, maybe, I will look for a decent (slim and silent) PWM-capable 12V fan and connect wires by myself as shaun27 suggested before. I've searched online shops quite a lot, and now I'm almost desperate to see thing exactly needed unless friendlyarm design it and start production soon. Link to comment Share on other sites More sharing options...
Hai.k.o Posted December 30, 2018 Share Posted December 30, 2018 Hello ! Same problem, another forum: https://forum.armbian.com/topic/9105-nanopc-t4-fan-connector Meanwhile I received the parts to build the connector/cable: On board: JST BM03B-GHS-TBT plug-housing: JST GHR-03V-S plug-contacts: JST MINI-SSHL-002T-P0.2 Soldering? Just forget it. The parts are so small. I just ordered a preconfigured cable via eBay. But the main problem seems to be that the fan is runnig at highest speed, ignoring the PWM signal. Link to comment Share on other sites More sharing options...
pfry Posted January 1, 2019 Share Posted January 1, 2019 On 12/30/2018 at 8:07 AM, Hai.k.o said: [...] But the main problem seems to be that the fan is runnig at highest speed, ignoring the PWM signal. It should be tough to ignore, given that it's monkeying with the duty cycle of the fan's power input. Do you have a way to measure it? Hm... I've never measured a PWM signal with a multimeter - I've always either just plugged into a PWM-capable board or wired up a voltage divider (mostly just a pot -> ground, as the fan has a voltage source if it runs with the PWM disconnected). Beyond playing with the little resistor pigtails that come with various PC fans, I've never tried to control fan speed using the supply voltage - too unreliable, and I prefer to work with a nice, low-current speed control (if possible). The NanoPC-T4 uses a nice big MOSFET on that fan supply line, so current draw shouldn't be an issue. Looks like a higher duty cycle on GPIO4_C6/PWM1 should slow the fan, if I'm reading it right. (Am I?) Link to comment Share on other sites More sharing options...
weigon Posted January 16, 2019 Share Posted January 16, 2019 (edited) On 1/1/2019 at 11:40 AM, pfry said: It should be tough to ignore, given that it's monkeying with the duty cycle of the fan's power input. Do you have a way to measure it? Hm... I've never measured a PWM signal with a multimeter - I've always either just plugged into a PWM-capable board or wired up a voltage divider (mostly just a pot -> ground, as the fan has a voltage source if it runs with the PWM disconnected). Beyond playing with the little resistor pigtails that come with various PC fans, I've never tried to control fan speed using the supply voltage - too unreliable, and I prefer to work with a nice, low-current speed control (if possible). The NanoPC-T4 uses a nice big MOSFET on that fan supply line, so current draw shouldn't be an issue. Looks like a higher duty cycle on GPIO4_C6/PWM1 should slow the fan, if I'm reading it right. (Am I?) I run 3-pin fan (Noise Blocker XM-1) connected to the FAN port of the T4. It is mounted on top of a "AAB Cooling NB Cooler 1" heatsink. GPIO4_C6 is exported as "pwm1" and can be used directly via sysfs: # export the PWM1-pin $ echo 0 > /sys/class/pwm/pwmchip1/export # setup PWM (5% duty-cycle) $ echo normal > /sys/class/pwm/pwmchip1/pwm0/polarity $ echo 100000 > /sys/class/pwm/pwmchip1/pwm0/period $ echo 5000 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle # enable the PWM output $ echo 1 > /sys/class/pwm/pwmchip1/pwm0/enable (The 5% duty cycle works for this small, light fan. For larger fans a higher duty cycle is need to get the fan started). At 100% duty-cycle the temperature of the T4 stays at 43C max under full load. I havn't found a way to read back the TACH signal that's available as GPIO2_A6_FAN_TACH yet to feed the information into fancontrol later. Edited January 16, 2019 by weigon added ref to heatsink Link to comment Share on other sites More sharing options...
suka Posted January 16, 2019 Share Posted January 16, 2019 What version are you on, and did you adjust anything else? Because it does not work for me neither on regular nor dev releases. I do see signal changing on the suggested tacho pin though, but haven't figured out how to read or apply them: cd /sys/class/gpio echo 70 > export cat gpio70/value Link to comment Share on other sites More sharing options...
weigon Posted January 18, 2019 Share Posted January 18, 2019 Yep, gpio70 does the trick. Use the below python script to print the current measured rounds: #!/usr/bin/env python ## $ pip install python-periphery from periphery import GPIO import datetime def fan_rpm(): with GPIO(70) as rpm_gpio: rpm_gpio = GPIO(70) assert rpm_gpio.supports_interrupts rpm_gpio.edge = "rising" while True: cur = datetime.datetime.now() start = cur end = cur + datetime.timedelta(seconds=1) time_left = end - cur rounds = 0 while time_left.total_seconds() > 0: if rpm_gpio.poll(time_left.total_seconds()): cur_val = rpm_gpio.read() if cur_val == True: rounds += 1 cur = datetime.datetime.now() time_left = end - cur print("rounds={:3}, RPM={:4.0f}".format( rounds, rounds * 60 / (cur - start).total_seconds())) if __name__ == "__main__": fan_rpm() A few measurements for different fans: For a Noctua NF A14 (1400x1400mm, max 1400 RPM): With period: 1000ns duty_cycle: 20ns, rounds/s: 0 duty_cycle: 50ns, rounds/s: 20 (1200 RPM) duty_cycle: 52ns, rounds/s: 40 (2400 RPM) duty_cycle: 900ns, rounds/s: 45 For NoiseBlocker XM1 (40x40mm, max 2800 RPM): With period: 1000ns duty_cycle: 20ns, rounds/s: 0 duty_cycle: 50ns, rounds/s: 45 (2700 RPM) duty_cycle: 52ns, rounds/s: 105 (6300 RPM) duty_cycle: 900ns, rounds/s: 110 1. using PWM to drive a DC fan leaves only a very small range that allows to control the fan-speed 2. the reported RPMs don't match the max-RPMs one would expect from the fan. Link to comment Share on other sites More sharing options...
weigon Posted January 18, 2019 Share Posted January 18, 2019 23 minutes ago, weigon said: 1. using PWM to drive a DC fan leaves only a very small range that allows to control the fan-speed 2. the reported RPMs don't match the max-RPMs one would expect from the fan. I just found out that the PWM freq should be 25kHz and that the TACH signal gives 2 ticks per round. That means: In the script I pasted earlier "rounds/s" were just ticks and the "RPM" were "twice the RPM". After adjusting the PWM freq the corrected measurements for the Noctua NF A14: duty_cycle: 170ns, stops duty_cycle: 180ns, ticks: ~3, RPM: 90 duty_cycle: 190ns, ticks: ~4, RPM: 120 duty_cycle: 200ns, ticks: 8, RPM: 240 duty_cycle: 250ns, ticks: 16, RPM: 480 duty_cycle: 300ns, ticks: 22, RPM: 660 duty_cycle: 350ns, ticks: 34, RPM: 1020 duty_cycle: 400ns, ticks: 40, RPM: 1200 duty_cycle: 500ns, ticks: 47, RPM: 1400 duty_cycle: 800ns, ticks: 36, RPM: 990 [*] duty_cycle: 2000ns, ticks: 24, RPM: 720 [*] duty_cycle: 2000ns, ticks: 26, RPM: 780 [*] duty_cycle: 4000ns, ticks: 40, RPM: 1200 [*] [*] fan is faster, but ticks aren't consistent. Link to comment Share on other sites More sharing options...
weigon Posted January 18, 2019 Share Posted January 18, 2019 After removing the noise from the input-data, I now got quite reasonable RPM values for the Noctua NF A14: RPM per duty_cycle [ns] duty_cycle RPM 180 158 200 476 250 637 300 938 400 1111 500 1200 2000 1251 Below 180ns the fan stops, above 500ns it doesn't really increase anymore. fan.svg 2 Link to comment Share on other sites More sharing options...
weigon Posted January 24, 2019 Share Posted January 24, 2019 Just for reference, a simplified version that works with both linux 4.4 and the linux 4.20 kernel: # make the PWM port available to sysfs $ echo 0 | sudo tee /sys/class/pwm/pwmchip1/export 0 # set the PWM-freq to 25kHz (=40000ns) $ echo 40000 | sudo tee /sys/class/pwm/pwmchip1/pwm0/period 40000 # enable the PWM $ echo 1 | sudo tee /sys/class/pwm/pwmchip1/pwm0/enable 1 It starts the fan at fullspeed as by default the polarity of the PWM is inversed: duty_cycle of "0" == "always on". $ cat /sys/class/pwm/pwmchip1/pwm0/polarity inversed $ cat /sys/class/pwm/pwmchip1/pwm0/duty_cycle 0 To slow the fan down with inversed polarity one needs to bring the duty_cycle close to the "period" set before $ echo 35000 | sudo tee /sys/class/pwm/pwmchip1/pwm0/duty_cycle 35000 1 Link to comment Share on other sites More sharing options...
i5Js Posted March 27, 2020 Share Posted March 27, 2020 How can I figure out which is the pin of the fan on my nanopc t4? Because when I run the script I get the following: Traceback (most recent call last): File "test_fan.py", line 36, in <module> fan_rpm() File "test_fan.py", line 8, in fan_rpm with GPIO(70) as rpm_gpio: File "/home/i5Js/.local/lib/python2.7/site-packages/periphery/gpio.py", line 32, in new return SysfsGPIO.__new__(cls, *args) TypeError: __new__() takes exactly 3 arguments (2 given) Thanks. Link to comment Share on other sites More sharing options...
