NetworkManger dispatcher problem
AlterX
Hi all,
I am trying to have a script running when eth0 i s up, but it seems that I don't get it. Although I followed a guide and set anything, NM is not triggering my script.
So I have created my script without sh extension and called it 90-start-script in /etc/NetworkManager/dispatcher.d:
logger -s "I DON'T SEE THIS"
if [ "$1" == "eth0" ]; then
        case "$2" in
                up)
                ~/scripts/start_check.sh
        esac
fi;
I gave it root ownership, execution flag, but it seems to be not working...
I followed this guide: https://wiki.archlinux.org/index.php/NetworkManager#Network_services_with_NetworkManager_dispatcher
I am running armbian 5.60 (strech)
Thanks
Did you take a look into /etc/NetworkManager/dispatcher.d directory to see how the other scripts do?
For example, I see that you miss the shebang at the very first lines of your script.
edit: also check the double equal (==) in the if statement. If I remember well, there should be a single equal there.
I have checked already the other scripts but they are really different from what I have...I have seen many example, who is using the single = who ==
anyway I tried all combinations...it also has the first line #!/bin/bash that I have just skipped.
The strange thing is that not even the first line of code is executed, only when I restart NetworkManager!
Thanks for the reply
Gianni
