NicoD Posted November 25, 2018 Share Posted November 25, 2018 Hi all. This is not Armbian related. But I don`t know where else to ask. I`m doing research on the NanoPi DUO2 running FriendlyCore with kernel 4.14 for my next review video. I would like to film the video with the DUO2. For that I`ve got a camera, it works. But only at 7 fp/s. On the FriendlyARM wiki it sais: Quote The mjpg-streamer utility uses libjpeg to software-encode steam data. The Linux-4.14 based ROM currently doesn't support hardware-encoding. If you use a H3 boards with Linux-3.4 based ROM you can use the ffmpeg utility to hardware-encode stream data and this can greatly release CPU's resources and speed up encoding: I tried searching for kernel 3.4. But I`m unable to find it(I think). This is what I get. I don`t think/know these are useable. pi@NanoPi-Duo2:~$ sudo apt-cache search linux-headers 3.4 linux-headers-3.4.0-1-hammerhead - Linux kernel headers for version 3.4.0 on Nexus 5 linux-headers-3.4.0-4-goldfish - Linux kernel headers for version 3.4.0 on Android touch emulation linux-headers-3.4.0-5-flo - Linux kernel headers for version 3.4.0 on Nexus 10 linux-headers-3.4.0-7-mako - Linux kernel headers for version 3.4.0 on Nexus 4 Could somebody please point me in the right direction on how to do this? I asked my contact at FriendlyElec but didn`t get a response. I`m a total noob at this, sorry. Greetings, NicoD Link to comment Share on other sites More sharing options...
TohaX Posted December 4, 2018 Share Posted December 4, 2018 https://drive.google.com/drive/folders/1bRKERrSwe6Fh4JlBEFMspoyqvV-0cQvF Link to comment Share on other sites More sharing options...
NicoD Posted December 4, 2018 Author Share Posted December 4, 2018 3 hours ago, TohaX said: https://drive.google.com/drive/folders/1bRKERrSwe6Fh4JlBEFMspoyqvV-0cQvF Super. Thank you very much. I`ll try it tonight. Greetings, NicoD Link to comment Share on other sites More sharing options...
NicoD Posted December 4, 2018 Author Share Posted December 4, 2018 Hi again @TohaX Do you work for FriendlyArm? I seem to experience a few issues with the image. On-board wifi doesn't work, wifi dongles do work. It runs a lot hotter than 4.14. Where it ran fine without a heatsink and fan, it now needs a heatsink + fan to have the same performance. It reached 80°C with a short 7z benchmark. With npi-config I can't change the cpu frequency to 1.2Ghz. It does work with cpufreq-set. I didn't have much better results with mjpg_streamer. Still 7fps in 720p, 2fps in 1080p and 22fps in 480p. I haven't put much time and effort into it yet. I need to re-check and compare everything to be sure. If you do work for FriendlyArm, could you please give me an email address that I can contact with my findings? Thank you, greetings. NicoD Link to comment Share on other sites More sharing options...
TohaX Posted December 5, 2018 Share Posted December 5, 2018 Нет. Я простой пользователь и только планирую покупку nanopi duo 2. Но теперь думаю, а стоит ли ее покупать, после описанных тобой недостатков? Link to comment Share on other sites More sharing options...
NicoD Posted December 5, 2018 Author Share Posted December 5, 2018 10 hours ago, TohaX said: Нет. Я простой пользователь и только планирую покупку nanopi duo 2. Но теперь думаю, а стоит ли ее покупать, после описанных тобой недостатков? Здравствуйте. Эта операционная система все еще нова. Я надеюсь, что эти недостатки будут решены. Пока что я не могу рекомендовать его для камеры безопасности, и есть более совершенные устройства для безголового сервера. Тем не менее, я думаю, что это отличная платформа. Надеюсь, что будет быстрое улучшение. Приветствия, NicoD Translation Hi. This Operating System is still new. I hope these shortcomings will be resolved. So far, I can not recommend it for a security camera, and there are better devices for a headless server. All tho, I believe it's a nice board. I hope it'll improve quickly. Greetings. Link to comment Share on other sites More sharing options...
