Ramblings and progress with the RK3399
pbies
This is so painful! out of about 50 attempts, I got it to boot once with the different DDR Version 1.14 20180803 displayed on serial comms,  but then it hang, I presume because I removed the short pin too quickly.
I also tried shorting the both sides of R90303 out in turn (which is closer to the eMMC IC in terms of electrical) , and I think  this did help for the 1 time I got it to work.
Now, the way that works best is to use a very short length of wire (its actually a header pin folded over 180 degrees) , to short out TP50265 and GND pins - this works 3 out of 5 times now., and I am able to get the Armbian login. Great!!
I also managed to press space bar within 2 seconds of booting, to access uboot, and did:
setenv devnum  1
run mmc_boot
but this did not persist on rebooting the unit.
I also tried changing the apparent order of boot devices:
setenv boot_targets 'mmc1 mmc0 usb0 pxe dhcp'
saveenv
but get this:
Saving Environment to EXT4...
** Unable to use mmc 0:auto for saveenv **
Failed (1)
did you do anything else to your uboot?
Thanks.
Spoiler
U-Boot 2018.11-armbian (Jan 26 2019 - 19:18:58 +0100)
Model: OrangePi boards based on Rockchip RK3399
DRAM:  2 GiB
MMC:   dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from EXT4... Card did not respond to voltage select!
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
rockchip_dnl_key_pressed: adc_channel_single_shot fail!
Net:
Error: ethernet@fe300000 address not set.
eth-1: ethernet@fe300000
Hit any key to stop autoboot:  0
=>       printenv
arch=arm
baudrate=1500000
board=evb_rk3399
board_name=evb_rk3399
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc0 mmc1 usb0 pxe dhcp
bootcmd=run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=0
cpu=armv8
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr_r=0x01f00000
fdtcontroladdr=7df212a8
kernel_addr_r=0x02080000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
partitions=uuid_disk=${uuid_gpt_disk};name=loader1,start=32K,size=4000K,uuid=${uuid_gpt_loader1};name=loader2,start=8MB,size=4MB,uuid=${uuid_gpt_loader2};name=trust,size=4M,uuid=${uuid_gpt_atf};name=boot,size=112M,bootable,uuid=${uuid_gpt_boot};name=rootfs,size=-,uuid=B921B045-1DF0-41C3-AF44-4C6F280D3FAE;
pxefile_addr_r=0x00600000
ramdisk_addr_r=0x04000000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x00500000
soc=rockchip
stderr=serial@ff1a0000
stdin=serial@ff1a0000
stdout=serial@ff1a0000
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=rockchip
Environment size: 3884/32764 bytes
=> saveenv
Failed (1)
=> setenv devnum 1
=> saveenv
Failed (1)
for reference - schematics.
Spoiler
This is the underside layout with R90303 circled - note this is for an older v1.4 board,  thats why I crossed out TP50265, because on v1.5 its on the top side.
Just for my understanding @martinayotte - when we make changes by "setenv ..."  after entering uboot by pressing space bar, that is trying to write to the uboot on eMMC, right? Do you think there is any write protect on this by default?
when trying to saveenv I still get
Failed (1)
Thanks
Have you installed Armbian to eMMC? Only after that, you can use those commands to boot from SD card again. If you need to - if you broke the OS on eMMC. If you totally broke everything, you need to enter Maskrom mode again by shorting pins ...
OK, well good and bad news -
I started getting very slow / inconsistent SSH and serial comms, but did manage to go through nand-sata-install via serial, and install to eMMC. Now I dont have Android on eMMC, and appears to be Armbian - great.
but now,  it just gets stuck in reboot cycle:
Spoiler
In
soft reset
SRX
Channel 0: DDR3, 800MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: DDR3, 800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x32817281, stride = 0x9
OUT
Boot1: 2018-08-06, version: 1.15
CPUId = 0x0
ChipType = 0x10, 272
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67464
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
GPT 0x3190d20 signature is wrong
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x99bc0
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):f947c7e
NOTICE:  BL31: Built : 12:34:33, Nov 26 2018
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    plat_rockchip_pmu_init(1089): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
DRAM:  2 GiB
Loading Environment from EXT4... OK
In:    serial@ff1a0000
Net:
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
2958 bytes read in 7 ms (412.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
188 bytes read in 2 ms (91.8 KiB/s)
8679416 bytes read in 1153 ms (7.2 MiB/s)
14031360 bytes read in 1851 ms (7.2 MiB/s)
74945 bytes read in 28 ms (2.6 MiB/s)
232 bytes read in 11 ms (20.5 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 39000000
## Loading init Ramdisk from Legacy Image at 04000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    8679352 Bytes = 8.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 7d6d7000, end 7df1dfb8 ... OK
   reserving fdt memory region: addr=1f00000 size=78000
   Loading Device Tree to 000000007d65c000, end 000000007d6d6fff ... OK
Starting kernel ...
[   20.725428] reboot: Restarting system
In
soft reset
SRX
256B stride
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67460
SecureMode = 0
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
INFO:    SPSR = 0x3c9
DRAM:  2 GiB
In:    serial@ff1a0000
Net:
Scanning mmc 0:1...
8679416 bytes read in 1134 ms (7.3 MiB/s)
14031360 bytes read in 1820 ms (7.4 MiB/s)
74945 bytes read in 29 ms (2.5 MiB/s)
232 bytes read in 12 ms (18.6 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
when I try to boot from SD card (I tried 3 different, recently opened from packet, and tried bionic images and Stretch), using space-bar to uboot, setenv devnum  1, run mmc_boot, I get this:
Spoiler
DRAM:  2 GiB
In:    serial@ff1a0000
Net:
=> setenv devnum 1
=> run mmc_boot
** Bad device specification mmc -bootable **
Scanning mmc :1...
Applying user provided fixup script (fixup.scr)
Wrong Ramdisk Image Format
Ramdisk image is corrupt or invalid
EDIT:
one of the SD cards just worked, so am in via serial, but it is all a little strange at the moment,  ill try installing to eMMC again with nand-sata-install.
EDIT2:
Ill try to verify the genuine-ness of these SD cards with H2testw. (they are Sandisk Ultra 16GB A1).
Any ideas?
Thanks
This suggest some corruption. Make sure you use good SD card (sometimes SD card brand or too fancy SD card could be an issue) and proven writing method ... and a good PSU to rule out most stupid errors.
printenv:
Spoiler
=> printenv
arch=arm
baudrate=1500000
board=evb_rk3399
bootargs=root=/dev/mmcblk0p1 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=593409a6-01 usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
bootdelay=0
bootfstype=ext4
console=both
consoleargs=console=ttyS2,1500000 console=tty1
cpu=armv8
devnum=1
devplist=1
devtype=mmc
docker_optimizations=on
fileaddr=500000
filesize=b8e
load_addr=0x39000000
overlay_error=false
partuuid=593409a6-01
rootdev=/dev/mmcblk0p1
rootfstype=ext4
soc=rockchip
vendor=rockchip
verbosity=1
Environment size: 4401/32764 bytes
when I try to boot from SD card now by pressing space bar to get into uboot, and do setenv devnum 1, run mmc_boot.
I just re-burnt this SD card with Etcher (validated OK), and changed PSU to a ATX PC style PSU.  (made no difference to the situation).
Spoiler
DRAM:  2 GiB
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial@ff1a0000
Net:
=> setenv devnum 1
=> run mmc_boot
Scanning mmc :1...
2958 bytes read in 6 ms (481.4 KiB/s)
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Wrong image format for "source" command
Bad Linux ARM64 Image magic!
Thanks
plugging in an HDMI and keyboard, I can login OK. I did nand-sata-install, and this time selected option 5 (Install/Update the bootloader on SD/eMMC), and then re-selected option 2 (boot from eMMC - system on eMMC).
so it boots now, but for some reason either the ethernet does not get a DHCP sometime, or when it does, putty hangs (as does SSH from a raspberry pi) when I type in the password. This is for root and normal users.
I need to take a break from this board for a while, but in passing, has anyone managed to get mini PCIe wifi boards working with this board? or with any RK3399 board (NEO4, etc)? I see no output from lspci.
Thanks
RK3399 board support and especially this board is months/a year away from being stable/matured. Those images were made for development/testing purposes only.  PCI stack on a modern kernel is completely broken at this moment. On all boards.
5 hours ago, gounthar said:
How can we power an SSD when using Sata on this board? Is there some kind of power splitter somewhere?
Hi.
There are multiple threads about that.
Look here.
Quote from @Da Alchemist
Quote
There must be two connections to the SSD of course, power and sata (there are cables for both connections).  If everthing is allright, there must be a green and a red LED turned on. Is your SSD formatted?  If not use Gparted to get it formatted.
I hope that helps.
12 hours ago, gounthar said:
The OrangePi RK3399 doesn't have that kind of Molex connector, but I will keep searching.
Thanks for your help.
The Orange Pi RK3399 has 5V and 3.3V available on the 40-pin header (and nowhere else that I can see offhand). Pinout is in the manual; it's a standard .1"/2.54mm header - lots of connector options. The mSATA interface is a bit inconvenient (uncommon); it also has 3.3V power available - perfect for an mSATA device; not much use if you're adapting it to a 2.5" device. I didn't check to see how much power is available, but I'd expect it to be fine for typical devices.
On 12/3/2018 at 1:04 AM, Myy said:
Alright, turns out that the
/path/to/your/rkdeveloptool rd # Reboot
step in my procedures wasn't rebooting the board anyway.
So, basically, when in Maskrom mode (the mode you are in when the serial console is quiet, or when you keep the "Recovery" button pushed with the Right U-Boot), all writes are "as-is".
If you reboot (unplug and plug the power cable back again) with a Loader, a Firmware and the Trust image, you'll get into a special "rockusb" mode that offset everything by 0x2000 sectors (0x2000 * 512 bytes).
Since I'm not interested in that special rockusb mode, here's the "right" process for installing a U-Boot and Trust.img when you are in "quiet" mode :
/path/to/your/rkdeveloptool db /path/to/RK3399MiniLoaderAll_V1.05_DDR600MHz.bin # Write the Bootloader
/path/to/your/rkdeveloptool ul /path/to/RK3399MiniLoaderAll_V1.05_DDR600MHz.bin # Which is also their firmware
/path/to/your/rkdeveloptool wl 0x4000 /path/to/uboot.img # Write the U-Boot image
/path/to/your/rkdeveloptool wl 0x6000 /path/to/trust.img # Write the Trust bits
# "Turn it off and on again" by unpluging and plugging the power cable back (Either the USB-C cable or the power plug)
# Rebooting through the little button generate "Tinkerboard"-esque issues with the eMMC, which won't be properly power up anymore.
Now, if you already have an eMMC image, you can do this instead :
/path/to/your/rkdeveloptool wl 0 /path/to/eMMC.img # This will be STUPIDLY slow. You'll have to wait betweens 10 and 30 minutes.
# Unplug and plug the power cable back again, after the command finishes.
I tested successfully these last steps and, therefore, have been able to directly flash my semi-working Armbian installation based on the Firefly RK3399 image.
So, the current step now is "Getting a Rockchip kernel working correctly with this board".
Thanks for these commands. They helped me getting my board out of a strange mode where it only displayed hw 0 0 0 0 0 0 0 0 0 0 and powerOn "someNumbers". Before that, I could not get into MASKROM mode anymore, nor in LOADER mode... It appeared kind of bricked to me.
By the way, I read there that one could get into MASKROM mode from software by zeroing part of the boot partition.
That's what got me into that "almost bricked" mode.
If anyone has the correct sequence of commands that could do it, I will use it from now on.
I made some progress with this board, but am still stuck with its Debian version because of the HDMI-IN thingie (upgraded to Sid).
I now have a working hardware accelerated ffmpeg for decoding (thanks to rkmpp), but no hardware accelerated encoding.
The RockChip gstreamer fork has h.264 hwaccel, but it freezes the board way too often.
OrangePi has finally made available a camera for this board, as the one from FriendlyArm froze the board too.
I haven't been able to recompile a kernel on the board itself yet, but I'm working on it.
I rebuilt the image for my RK3399 two days ago, and it is stuck at boot with this message:
Spoiler
DDR Version 1.08 20170320
In
256B stride
OUT
Boot1: 2017-04-07, version: 1.06
CPUId = 0x0
ChipType = 0x10, 1836
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14922MB
FwPartOffset=2000 , 0
StorageInit ok = 111125
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing BL32
I rebuilt it today, and have the same output:
Spoiler
In
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 1833
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14922MB
StorageInit ok = 172930
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
I also downloaded Armbian Buster desktop legacy kernel 4.4.y and I got
Spoiler
In
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 1827
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14922MB
StorageInit ok = 310967
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
Unhandled Exception in EL3.
x30 =           0x0000000000034b84
x0 =            0x0000000000000238
x1 =            0x0000000000039f40
x2 =            0x000000000001fe18
x3 =            0x00000000ff00fff0
x4 =            0x0000000000034260
x5 =            0x0000000000034288
x6 =            0x0000000000000000
x7 =            0x0000000000000000
x8 =            0x0000000003011e8e
x9 =            0x00000000032c0768
x10 =           0x0000000000010024
x11 =           0x0000000000000000
x12 =           0x000000000000000a
x13 =           0x0000000000000001
x14 =           0x0000000000000002
x15 =           0x0000000000000004
x16 =           0x0000000000000000
x17 =           0x0000000000000000
x18 =           0x0000000000800000
x19 =           0x000000000001000c
x20 =           0x00000000ff8cf800
x21 =           0x0000000000000000
x22 =           0x0000000000000010
x23 =           0x0000000000000000
x24 =           0x0000000000080000
x25 =           0x0000000000000001
x26 =           0x00000000ff8c2000
x27 =           0x0000000000000484
x28 =           0x0000000000000484
x29 =           0x00000000032c1040
scr_el3 =               0x0000000000000238
sctlr_el3 =             0x0000000000c5383a
cptr_el3 =              0x0000000000000000
tcr_el3 =               0x0000000000000000
daif =          0x00000000000003c0
mair_el3 =              0x44e048e000098aa4
spsr_el3 =              0x00000000200002cd
elr_el3 =               0x000000000001003c
ttbr0_el3 =             0x001010e01200d312
esr_el3 =               0x00000000bf000000
far_el3 =               0x0000100a4204913e
spsr_el1 =              0x0000000080028100
elr_el1 =               0xc1286301c01b1841
spsr_abt =              0x000000004a010743
spsr_und =              0x00000000c00147a4
spsr_irq =              0x0000000006046448
spsr_fiq =              0x000000002a042040
sctlr_el1 =             0x0000000000c52838
actlr_el1 =             0x0000000000000000
cpacr_el1 =             0x0000000000000000
csselr_el1 =            0x0000000000000000
sp_el1 =                0x0c92280013b001a4
esr_el1 =               0x0000000020d41000
ttbr0_el1 =             0x8971000a12c15a02
ttbr1_el1 =             0x202280a0b6028091
mair_el1 =              0x44e048e000098aa4
amair_el1 =             0x0000000000000000
tcr_el1 =               0x0000000000000000
tpidr_el1 =             0x5300022005293004
tpidr_el0 =             0x803208440d028422
tpidrro_el0 =           0x6904246005000888
dacr32_el2 =            0x000000002a208214
ifsr32_el2 =            0x0000000000000000
par_el1 =               0x2800000045e34a43
mpidr_el1 =             0x0000000080000000
afsr0_el1 =             0x0000000000000000
afsr1_el1 =             0x0000000000000000
contextidr_el1 =                0x0000000000000000
vbar_el1 =              0x0000000000000000
cntp_ctl_el0 =          0x0000000000000000
cntp_cval_el0 =         0x93c8300008001002
cntv_ctl_el0 =          0x0000000000000000
cntv_cval_el0 =         0x0181006046a02120
cntkctl_el1 =           0x0000000000000000
fpexc32_el2 =           0x0000000000000700
sp_el0 =                0xd944a09a80152021
isr_el1 =               0x0000000000000000
cpuectlr_el1 =          0x0000000000000040
cpumerrsr_el1 =         0x0000000000000000
l2merrsr_el1 =          0x0000000000000000
gicc_hppir =            0x0000000000000000
gicc_ahppir =           0x0000000000000000
gicc_ctlr =             0x0000000014000082
gicd_ispendr regs (Offsets 0x200 - 0x278)
0000000000000200:               0x0000001800000000
0000000000000208:               0x0000000000000000
0000000000000210:               0x0000000000000010
0000000000000218:               0x0000000000000000
0000000000000220:               0x0000000000000000
0000000000000228:               0x0000000000000000
0000000000000230:               0x0000000000000000
0000000000000238:               0x0000000000000000
0000000000000240:               0x0000000000000000
0000000000000248:               0x0000000000000000
0000000000000250:               0x0000000000000000
0000000000000258:               0x0000000000000000
0000000000000260:               0x0000000000000000
0000000000000268:               0x0000000000000000
0000000000000270:               0x0000000000000000
0000000000000278:               0x0000000000000000
cci_snoop_ctrl_cluster0 =               0x00000000c0000000
cci_snoop_ctrl_cluster1 =               0x00000000c0000000
With Buster minimal 5.4 I got
Spoiler
In
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 1826
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14922MB
StorageInit ok = 268186
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
x30 =           0xUnhandled Exception in EL3.
With Buster server I got:
Spoiler
In
256B stride
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14922MB
StorageInit ok = 292962
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
ttbr0_el3 =             0x001011e01200db1b
far_el3 =               0x0000100a420491ac
elr_el1 =               0xc1284309c11b1841
spsr_und =              0x00000000c00146a6
spsr_irq =              0x0000000086046448
sp_el1 =                0x0c1228001bb000a0
esr_el1 =               0x0000000020941000
ttbr0_el1 =             0x8921000a02c15a02
ttbr1_el1 =             0x202080a016228091
tpidr_el1 =             0x4300022005283004
tpidr_el0 =             0x803208400d068422
dacr32_el2 =            0x000000002a208204
cntv_cval_el0 =         0x0181106046a02130
sp_el0 =                0xd944b09a80142021
Today's build went farther on the OrangePi RK3399:
Spoiler
=> setenv devnum 1
=> run mmc_boot
mmc1 is current device
Scanning mmc 1:1...
2940 bytes read in 21 ms (136.7 KiB/s)
Boot script loaded from mmc 1
139 bytes read in 18 ms (6.8 KiB/s)
6975843 bytes read in 477 ms (13.9 MiB/s)
20587008 bytes read in 1346 ms (14.6 MiB/s)
73823 bytes read in 58 ms (1.2 MiB/s)
2698 bytes read in 32 ms (82 KiB/s)
   Image Name:   uInitrd
   Data Size:    6975779 Bytes = 6.7 MiB
   Loading Ramdisk to 7d859000, end 7df00123 ... OK
   Loading Device Tree to 000000007d7de000, end 000000007d858fff ... OK
Starting kernel ...
It is now stuck, but it never got that far previously for me.
