gounthar Posted December 17, 2019 Share Posted December 17, 2019 I don't really know. How long is long? I waited 25 minutes and got nothing. Your thoughts? Link to comment Share on other sites More sharing options...
Igor Posted December 17, 2019 Share Posted December 17, 2019 8 minutes ago, gounthar said: I waited 25 minutes and got nothing. Not that long Huh. No idea atm. Link to comment Share on other sites More sharing options...
gounthar Posted December 19, 2019 Share Posted December 19, 2019 So I tried this image found on this thread (Single Armbian image for RK + AML + AW), and it goes farther: Spoiler 21.071024] rockchip-dmc dmc: Cannot get the regulator "center" [ 21.075233] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok [ 21.082156] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 21.085584] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 21.088899] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 21.092092] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 21.095717] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 21.098905] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 21.103073] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 21.106413] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 21.109609] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 21.112675] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 21.116734] rockchip-dmc dmc: Cannot get the regulator "center" [ 21.120188] console [netcon0] enabled [ 21.123168] netconsole: network logging started [ 21.126934] input: gpio-keys as /devices/platform/gpio-keys/input/input1 And later today, I always have the infamous "mmc_init: -5, time 4" error when I try the run mmc_boot. Go figure. I'm fed up with this card, nothing is stable. When it looks broken (EL3 errors, or kernel panic, or whatever) I can boot on the SDCard, but there isn't any image that boots until the end. When it gets back to life for whatever reason, I can't boot on the SDCard anymore. I would just like to install Armbian, or push another version of the existing kernel so that I can at last use the camera. Link to comment Share on other sites More sharing options...
gounthar Posted January 3, 2020 Share Posted January 3, 2020 I rebuilt the image today, and I am still stuck at Starting kernel ... Spoiler Hit any key to stop autoboot: 0 => setenv devnum 1 => run mmc_boot switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2940 bytes read in 43 ms (66.4 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 139 bytes read in 35 ms (2.9 KiB/s) 7106982 bytes read in 515 ms (13.2 MiB/s) 20654592 bytes read in 1378 ms (14.3 MiB/s) 73823 bytes read in 110 ms (655.3 KiB/s) 2698 bytes read in 63 ms (41 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 39000000 ## Loading init Ramdisk from Legacy Image at 04000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7106918 Bytes = 6.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to 7d839000, end 7df00166 ... OK reserving fdt memory region: addr=1f00000 size=78000 Loading Device Tree to 000000007d7be000, end 000000007d838fff ... OK Starting kernel ... I guess my board may be faulty. Link to comment Share on other sites More sharing options...
