Odroid XU4 - CPU temp discrepancy
akovia
I'm curious how the CPU temp value is calculated on the MOTD screen when ssh'ing in.
Mine is showing 56°C, but if I run the commands:
# cat /sys/devices/virtual/thermal/thermal_zone*/temp
45000
44000
48000
44000
41000
# armbianmonitor -m
Stop monitoring using [ctrl]-[c]
Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
12:16:28:  600/ 600MHz  0.17   1%   0%   0%   0%   0%   0% 45.0°C  0/3
Thanks
38 minutes ago, Igor said:
Thanks @Igor
I guess it's over my head. It looks like it's reading from /etc/armbianmonitor/datasources/soctemp which is the same value I was getting from armbianmonitor.
Seems I can just ignore the motd value safely.
7 hours ago, rooted said:
When you are logging into SSH it spins the CPU up for a second which generates heat, after logging in the CPU usage spike goes down as does the temperature.
Sounds reasonable but don't think that's it.
If you run these commands back to back after being logged in, you can see the difference.
root@odroidxu4:~# cat /etc/armbianmonitor/datasources/soctemp
44000
root@odroidxu4:~# cat /var/run/motd.dynamic
  ___      _           _     _  __  ___   _ _  _
 / _ \  __| |_ __ ___ (_) __| | \ \/ / | | | || |
| | | |/ _` | '__/ _ \| |/ _` |  \  /| | | | || |_
| |_| | (_| | | | (_) | | (_| |  /  \| |_| |__   _|
 \___/ \__,_|_|  \___/|_|\__,_| /_/\_\\___/   |_|
Welcome to ARMBIAN 5.60 stable Debian GNU/Linux 9 (stretch) 4.14.69-odroidxu4
System load:   0.01 0.02 0.00      Up time:       12:34 hours
Memory usage:  7 % of 1996MB     IP:
CPU temp:      52°C
