build image with hardware config and time zone
Hello
I use compile.sh and customize-image.sh to make my own custom image and every think is all right and work great.
This is my command line to compile:
sudo ./compile.sh
KERNEL_CONFIGURE="no"
KERNEL_ONLY="no"
BOARD="orangepipc2"
BRANCH="next"
RELEASE="xenial"
BUILD_DESKTOP="yes"
After burned my image and lounch Armbian I have to do two steps:
1) go to armbian config and set taggle hardware config "i2c0" option to "true" (like on picture 1.png)
2) go to armbian config and set time zone = Europe/Moscow
I tried to set KERNEL_CONFIGURE="yes" and try to find this options in configmenu = I did not find
I tried to add option TZDATA="Europe/Moscow" to command line = dose not work
What can I do to do this steps automaticaly in compile.sh or customize-image.sh?
Observe the difference in the /boot/armbianEnv.txt That you need to change in the build time if you want to have an image ready with those things applied.
Use Google and search hot to set time zone in a script for Debian or Ubuntu. Xenial in your case as I can see. This is not an question for Armbian.
Those are kernel features. Timezone is userspace feature which must be set with "customzite-image.sh" script.
