How to apt-get upgrade without loosing kernel AppleTalk?
mabam
Hello!
In order to compile software on my Banana Pi running Armbian 5.27 Debian 8, I started off uncommenting the "# deb-src" lines in /etc/apt/sources.list and then ran apt-get update and apt-get upgrade. The start screen in the shell would then ask me to reboot as the kernel was updated. But after the reboot there was no AppleTalk anymore to serve my old devices.
Compiling a newer Armbian with an up-to-date version of Debian is of no use to me as I run software (A2SERVER) that is incompatible with newer systems. So how can I upgrade my system without loosing AppleTalk (which I configured as a kernel module when compiling two years ago)?
EDIT:
I had done this on a spare SD-card onto which I have restored the old state from a backup. So I can start over.
Based on https://unix.stackexchange.com/questions/63293/blocking-kernel-updates-with-dpkg, I have performed the following steps:
dpkg -l | grep linux-image
which returned
hi  linux-image-sun7i              5.27                             armhf        Linux kernel, version 3.4.113-sun7i
followed by:
echo linux-image-sun7i hold | sudo dpkg --set-selections
After I continued with upgrading as described in my initial post, the login screen still asked me to restart because the kernel was updated. But this time AppleTalk still worked after restarting.
Glad to have found a solution!
This is more like a workaround. If some feature is enabled only in your custom kernel and you want to stay with uptodate kernel, adjust upstream config https://github.com/armbian/build/blob/master/config/kernel/linux-sun7i-default.config#L942 to yours this way: https://www.armbian.com/get-involved
After updated kernel is out, you can unhold your kernel package.
