Do you have a RK3399 board w/Armbian 18.04 ? Want to try my plexmediaplayer (modified to to use DRI for vo) installler ?
jerryn
I made a custom Plex Media Player build that leverages the decent performance we get with the fbdev/dri driver.
I tested Rockchip MPP gstreamer plugin.   The Rockchip Hardware VPU is very basic, it breaks with mkv playback, so I decided to use ffmpeg software decoding since it's extremely robust. Also 1080p playback through DRI isn't too shabby!.  If you want 4k video then you need to contact Rockchip.   They seem to be overwhelmed or not interested in bringing 4k support to Linux.   I built a .deb package that will install plexmediaplayer to /usr/local.  No worries about installing to somewhere and clobbering an official library or package.    Official Armbian dependencies will be installed to the proper location.  The plexmedia web-client will be installed to /usr/local/share/plexmediaplayer, the Qt5 binary will be installed to /usr/local/bin/plexmediaplayer
install with:
gdebi plex-media-player-install.deb
remove with:
apt-get remove plex-media-player-installer
To fix the installer package I basically reflashed my NanoPC-T4 with a clean Armbian image,  printed out the errors.
Updated the Debian control file with all the proper dependencies.
Here's the binary install package.
If you get a dependency error you can use the --ignore-depends dpkg argument and resolve after the install.
The files are installed in an easy location to clean up.
Edited by jerryn
Fixed the installer package, performed testing on a clean image. This is now ready to install
Fantastic. I am downloading it now and will install tomorrow. I am having trouble playing x265 on my M4 Bionic armbian.
Seasalt
18 hours ago, jerryn said:
install with:
dpkg -i plex-media-player-install.deb
Hi. I`ve tried it on Armbian Bionic on the M4 but it didn`t work.
Here`s what I did.
nicod@nanopim4:~$ cd Downloads/
nicod@nanopim4:~/Downloads$ sudo dpkg -i plex-media-player-install.deb
[sudo] password for nicod:
dpkg: error processing archive plex-media-player-install.deb (--install):
 package architecture (aarch64) does not match system (arm64)
Errors were encountered while processing:
nicod@nanopim4:~/Downloads$ sudo dpkg --add-architecture aarch64
Selecting previously unselected package plex-media-player-installer:aarch64.
(Reading database ... 108720 files and directories currently installed.)
Preparing to unpack plex-media-player-install.deb ...
Unpacking plex-media-player-installer:aarch64 (1.0) ...
dpkg: dependency problems prevent configuration of plex-media-player-installer:aarch64:
 plex-media-player-installer:aarch64 depends on libharfbuzz.
 plex-media-player-installer:aarch64 depends on libfreetype6.
 plex-media-player-installer:aarch64 depends on libfontconfig1.
 plex-media-player-installer:aarch64 depends on libx11.
 plex-media-player-installer:aarch64 depends on libxrandr.
 plex-media-player-installer:aarch64 depends on libvdpau.
 plex-media-player-installer:aarch64 depends on libva.
 plex-media-player-installer:aarch64 depends on mesa-common-dev.
 plex-media-player-installer:aarch64 depends on libegl1-mesa.
 plex-media-player-installer:aarch64 depends on libasound2.
 plex-media-player-installer:aarch64 depends on libpulse.
 plex-media-player-installer:aarch64 depends on libuchardet.
 plex-media-player-installer:aarch64 depends on zlib1g.
 plex-media-player-installer:aarch64 depends on libfribidi.
 plex-media-player-installer:aarch64 depends on libgnutls.
 plex-media-player-installer:aarch64 depends on libgl1-mesa.
 plex-media-player-installer:aarch64 depends on libsdl2.
 plex-media-player-installer:aarch64 depends on qt5-default.
 plex-media-player-installer:aarch64 depends on libqt5webkit5.
 plex-media-player-installer:aarch64 depends on qtlocation5.
 plex-media-player-installer:aarch64 depends on qtsensors5.
 plex-media-player-installer:aarch64 depends on qtdeclarative5.
 plex-media-player-installer:aarch64 depends on libsqlite3.
 plex-media-player-installer:aarch64 depends on libqt5webchannel5.
 plex-media-player-installer:aarch64 depends on libqt5webengine-data.
 plex-media-player-installer:aarch64 depends on libqt5webengine5.
 plex-media-player-installer:aarch64 depends on libqt5webenginecore5.
 plex-media-player-installer:aarch64 depends on libqt5webenginewidgets5.
 plex-media-player-installer:aarch64 depends on libqt5widgets5.
 plex-media-player-installer:aarch64 depends on libqt5x11extras5.
 plex-media-player-installer:aarch64 depends on libqt5multimedia5.
 plex-media-player-installer:aarch64 depends on libqt5multimedia5-plugins.
 plex-media-player-installer:aarch64 depends on libqt5multimediaquick-p5.
 plex-media-player-installer:aarch64 depends on libqt5multimediawidgets5.
 plex-media-player-installer:aarch64 depends on libqt5network5.
 plex-media-player-installer:aarch64 depends on libqt5opengl5.
 plex-media-player-installer:aarch64 depends on libqt5positioning5.
 plex-media-player-installer:aarch64 depends on libqt5positioning5-plugins.
 plex-media-player-installer:aarch64 depends on mvp.
dpkg: error processing package plex-media-player-installer:aarch64 (--install):
 dependency problems - leaving unconfigured
Any idea?
2 minutes ago, jerryn said:
Please open a console and run:
uname -a
nicod@nanopim4:~/Downloads$ uname -a
Linux nanopim4 4.4.162-rk3399 #41 SMP Fri Oct 26 14:03:47 CEST 2018 aarch64 aarch64 aarch64 GNU/Linux
I`m having now also having unmet dependencies:
nicod@nanopim4:~/Downloads$ sudo apt update
Hit:1 http://ports.ubuntu.com bionic InRelease
Hit:2 http://ports.ubuntu.com bionic-security InRelease
Hit:3 http://ports.ubuntu.com bionic-updates InRelease
Hit:4 http://ports.ubuntu.com bionic-backports InRelease
Ign:6 http://repo.vivaldi.com/snapshot/deb stable InRelease
Hit:7 http://repo.vivaldi.com/snapshot/deb stable Release
Hit:5 https://apt.armbian.com bionic InRelease
Reading package lists... Done
Building dependency tree
45 packages can be upgraded. Run 'apt list --upgradable' to see them.
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://repo.vivaldi.com/snapshot/deb stable InRelease' doesn't support architecture 'arm64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://repo.vivaldi.com/snapshot/deb stable InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://apt.armbian.com bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'bionic-utils/binary-aarch64/Packages' as repository 'http://apt.armbian.com bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'bionic-desktop/binary-aarch64/Packages' as repository 'http://apt.armbian.com bionic InRelease' doesn't support architecture 'aarch64'
nicod@nanopim4:~/Downloads$ sudo dpkg -r plex-media-player-install
dpkg: warning: ignoring request to remove plex-media-player-install which isn't installed
It`s just a test image so no problem
Again many dependency problems
Selecting previously unselected package plex-media-player-installer.
(Reading database ... 108734 files and directories currently installed.)
Unpacking plex-media-player-installer (1.0) ...
 plex-media-player-installer depends on libharfbuzz; however:
  Package libharfbuzz is not installed.
 plex-media-player-installer depends on libx11; however:
  Package libx11 is not installed.
 plex-media-player-installer depends on libxrandr; however:
  Package libxrandr is not installed.
 plex-media-player-installer depends on libvdpau; however:
  Package libvdpau is not installed.
 plex-media-player-installer depends on libva; however:
  Package libva is not installed.
 plex-media-player-installer depends on mesa-common-dev; however:
  Package mesa-common-dev is not installed.
 plex-media-player-installer depends on libpulse; however:
  Package libpulse is not installed.
 plex-media-player-installer depends on libuchardet; however:
  Package libuchardet is not installed.
 plex-media-player-installer depends on libfribidi; however:
  Package libfribidi is not installed.
 plex-media-player-installer depends on libgnutls; however:
  Package libgnutls is not installed.
 plex-media-player-installer depends on libgl1-mesa; however:
  Package libgl1-mesa is not installed.
 plex-media-player-installer depends on libsdl2; however:
  Package libsdl2 is not installed.
 plex-media-player-installer depends on qt5-default; however:
  Package qt5-default is not installed.
 plex-media-player-installer depends on qtlocation5; however:
  Package qtlocation5 is not installed.
 plex-media-player-installer depends on qtsensors5; however:
  Package qtsensors5 is not installed.
 plex-media-player-installer depends on qtdeclarative5; however:
  Package qtdeclarative5 is not installed.
 plex-media-player-installer depends on libsqlite3; however:
  Package libsqlite3 is not installed.
 plex-media-player-installer depends on libqt5webengine-data; however:
  Package libqt5webengine-data is not installed.
 plex-media-player-installer depends on libqt5webengine5; however:
  Package libqt5webengine5 is not installed.
 plex-media-player-installer depends on libqt5webenginecore5; however:
  Package libqt5webenginecore5 is not installed.
 plex-media-player-installer depends on libqt5webenginewidgets5; however:
  Package libqt5webenginewidgets5 is not installed.
 plex-media-player-installer depends on libqt5multimedia5; however:
  Package libqt5multimedia5 is not installed.
 plex-media-player-installer depends on libqt5multimedia5-plugins; however:
  Package libqt5multimedia5-plugins is not installed.
 plex-media-player-installer depends on libqt5multimediaquick-p5; however:
  Package libqt5multimediaquick-p5 is not installed.
 plex-media-player-installer depends on libqt5multimediawidgets5; however:
  Package libqt5multimediawidgets5 is not installed.
 plex-media-player-installer depends on libqt5opengl5; however:
  Package libqt5opengl5 is not installed.
 plex-media-player-installer depends on libqt5positioning5-plugins; however:
  Package libqt5positioning5-plugins is not installed.
 plex-media-player-installer depends on mvp; however:
  Package mvp is not installed.
dpkg: error processing package plex-media-player-installer (--install):
When I try to install them manually:
nicod@nanopim4:~/Downloads$ sudo apt install libharfbuzz libx11
Package libharfbuzz is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package libx11 is not available, but is referred to by another package.
E: Package 'libharfbuzz' has no installation candidate
E: Package 'libx11' has no installation candidate
A missing repo maybe?
I have the latest stable Armbian release.
I will boot my NanoPC-T4 on an SD and install the package on the SD image.
Hopefully I will run into the same problem and fix it.   I will look at this soon.  Thanks for trying
Thank you for wanting to do this.
I`m going to sleep,  I`ll see tomorrow if it worked for you.
Thanks
Ok everybody.  When you install the plex-media-player-install.deb package, use gdebi
I did a lot of testing on a new clean Armbian image.  If you test it please let me know if it works for you.
I tested with remote and local plex servers.
The installer created an entry in the Applications/Multimedia Menu.  Run Plex from there.   To exit hit escape.
All CEC commands should work.    Esc is Exit from full screen video playback back to plex.
