GLinBoy Posted December 13, 2018 Share Posted December 13, 2018 (edited) Hi I try use Nokia 5110 with Orange pi zero. I found this library: https://github.com/rm-hull/luma.lcd and try to run it on my orange pi with this tutorial: http://codelectron.com/interface-nokia-5110-lcd-and-raspberry-pi-python/ so in python shell I add these: >>> from luma.core.interface.serial import spi >>> from luma.core.render import canvas >>> from luma.lcd.device import pcd8544, st7735, uc1701x >>> import OPi.GPIO as GPIO >>> from luma.lcd.aux import backlight but after add this line, I got many error that told me that library is used for Raspberry pi only: >>> serial = spi(port=1, device=0, gpio_DC=18, gpio_RST=16) Traceback (most recent call last): File "/usr/local/lib/python3.6/dist-packages/luma/core/lib.py", line 23, in __rpi_gpio__ import RPi.GPIO as GPIO File "/usr/local/lib/python3.6/dist-packages/RPi/GPIO/__init__.py", line 23, in <module> from RPi._GPIO import * RuntimeError: This module can only be run on a Raspberry Pi! During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/usr/local/lib/python3.6/dist-packages/luma/core/interface/serial.py", line 255, in __init__ bitbang.__init__(self, gpio, transfer_size, DC=gpio_DC, RST=gpio_RST) File "/usr/local/lib/python3.6/dist-packages/luma/core/interface/serial.py", line 148, in __init__ self._gpio = gpio or self.__rpi_gpio__() File "/usr/local/lib/python3.6/dist-packages/luma/core/lib.py", line 30, in __rpi_gpio__ 'GPIO access not available') luma.core.error.UnsupportedPlatform: GPIO access not available Now I confused because in the document they said that we can use it on orange pi zero by armbian! Quote It was originally tested with Raspbian on a rev.2 model B, with a vanilla kernel version 4.1.16+, and has subsequently been tested on Raspberry Pi (both Raspbian Jessie and Stretch) models A, B2, 3B, Zero, Zero W and OrangePi Zero (Armbian Jessie). could you guide me to run Nokia 5110 LCD with orange pi zero (I prefer use python). Edited December 13, 2018 by GLinBoy Link to comment Share on other sites More sharing options...
martinayotte Posted December 13, 2018 Share Posted December 13, 2018 According to https://github.com/rm-hull/luma.core/blob/master/luma/core/lib.py#L23 , it is still using "import RPi.GPIO as GPIO" . You would have to change that with "import OPi.GPIO as GPIO" and maybe at some other places ... Link to comment Share on other sites More sharing options...
guidol Posted December 13, 2018 Share Posted December 13, 2018 56 minutes ago, GLinBoy said: >>> from luma.core.interface.serial import spi >>> from luma.core.render import canvas >>> from luma.lcd.device import pcd8544, st7735, uc1701x >>> import OPi.GPIO as GPIO >>> from luma.lcd.aux import backlight Now I confused because in the document they said that we can use it on orange pi zero by armbian! could you guide me to run Nokia 5110 LCD with orange pi zero (I prefer use python). 3 maybe your import of Opi.GPIO is to short? Did you read the documentation at https://pypi.org/project/OrangePi.GPIO/ https://opi-gpio.readthedocs.io/en/latest/api-documentation.html#importing-the-module https://opi-gpio.readthedocs.io/en/latest/https://opi-gpio.readthedocs.io/en/latest/install.html import OPi.GPIO as GPIO GPIO.setboard(GPIO.ZEROPLUS) GPIO.setmode(GPIO.BOARD) GPIO.output(5, 1) https://www.tindie.com/products/seandepagnier/orangepi-zero-nokia-5110-lcd-hat/ http://pcbrelated.com/playing-with-orange-pi-zero-part-1/ This orangepi version is different from the raspberrypi version because the gpio connector was flipped 180 degrees. ====================================================================================================================== My LCD module has an 8 pin connector so I use a connection like below: 1 - GND: Ground 2 - BL: Backlight 3 - 3VCC: Power, 3v3 4 - CLK: Clock for SPI -> (Orange Pi SPI-CLK pin 23) 5 - DIN: MOSI for SPI -> (Orange Pi SPI-MOSI pin 19) 6 - DC: Data/Command -> (Orange Pi IO-3 pin 15) 7 - CE: Chips Select -> (Orange Pi IO-0 pin 11) 8 - RST: Reset -> (Orange Pi IO-6 pin 22) Link to comment Share on other sites More sharing options...
guidol Posted December 13, 2018 Share Posted December 13, 2018 7 minutes ago, martinayotte said: You would have to change that with "import OPi.GPIO as GPIO" and maybe at some other places ... 1 The free Editor Notepad++ has a special feature for this Link to comment Share on other sites More sharing options...
GLinBoy Posted December 13, 2018 Author Share Posted December 13, 2018 2 hours ago, martinayotte said: it is still using "import RPi.GPIO as GPIO" . You would have to change that with "import OPi.GPIO as GPIO" and maybe at some other places That was. Thanks. Now everything build successfully but LCD doesn't show anything! 2 hours ago, guidol said: import OPi.GPIO as GPIO GPIO.setboard(GPIO.ZEROPLUS) GPIO.setmode(GPIO.BOARD) GPIO.output(5, 1) It's works perfect, But I can't handle LCD. Link to comment Share on other sites More sharing options...
GLinBoy Posted December 13, 2018 Author Share Posted December 13, 2018 For connect to SPI in python, which library should I use? Currently I used spidev. Is it correct? (Armbian_5.65_Orangepizero_Ubuntu_bionic) Link to comment Share on other sites More sharing options...
martinayotte Posted December 13, 2018 Share Posted December 13, 2018 19 minutes ago, GLinBoy said: For connect to SPI in python, which library should I use? I usually using this one for several OPis : https://github.com/duxingkei33/orangepi_PC_gpio_pyH3 This one is a fork specific to OPiZero : https://github.com/nvl1109/orangepi_zero_gpio Link to comment Share on other sites More sharing options...
