I can not switch channels other than 36 and 44
nikolai petrov
I have Espressobin v7 1G and PCIe card WLE900VX. With armbian-config create AP.  Starts successfully on 36 channels. I tried all the channels in 5Ghz, but works only successfully at 36 and 44.
By selecting another channel tells me after trying that I can not start AP on 5Ghz and start at 2GHz   successfull.
Any idea how to deal with this?
On 12/17/2018 at 4:26 PM, JDL said:
How did you get armbian running on the v7 board? Are you using the 17.10 based boot loader, and what kernel version are you using?
I copied the image of the USB flash. Boot of him. I had an image on USB flash, which I copy to an emmc espressobin. Boot from emmc and everything is ok.
U-Boot 2017.03-armada-17.10.2-g14aeedc (Jun 01 2018 - 15:39:10 +0800)
Linux espressobin 4.18.16-mvebu64 #402 SMP PREEMPT Fri Oct 26 17:23:18 CEST 2018 aarch64 GNU/Linux
You can try to boot Armbian Stretch or Armbian Bionic with kernel 4.18.x and your preinstalled u-boot 17.x on your V7 EspressoBin based on the following environment settings (to be entered at the Marvell>> prompt):
#boot from SD:
env default -a
setenv boot_interface mmc
setenv image_name boot/Image
setenv fdt_name boot/dtb/marvell/armada-3720-espressobin.dtb
setenv fdt_high "0xffffffffffffffff"
setenv rootdev "/dev/mmcblk1p1"
setenv root root=/dev/mmcblk1p1 rw
setenv rootfstype "ext4"
setenv verbosity "1"
setenv initrd_addr "0x1100000"
setenv initrd_image "boot/uInitrd"
setenv bootcmd 'mmc dev 0; ext4load mmc 0:1 $kernel_addr $image_name;ext4load mmc 0:1 $initrd_addr $initrd_image; ext4load mmc 0:1 $fdt_addr $fdt_name_a;ext4load mmc 0:1 $fdt_addr $fdt_name_b;setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr'
saveenv
#OR boot from SCSI:
env default -a
setenv boot_interface scsi
setenv rootdev "/dev/sda1"
setenv root root=/dev/sda1 rw
setenv bootcmd 'scsi scan; scsi dev 0; ext4load scsi 0:1 $kernel_addr $image_name;ext4load scsi 0:1 $initrd_addr $initrd_image; ext4load scsi 0:1 $fdt_addr $fdt_name;setenv bootargs $console root=$rootdev rw rootwait; booti $kernel_addr $initrd_addr $fdt_addr'
saveenv
8 hours ago, sfx2000 said:
Getting the 5GHz channels - you need to set the regulatory domain...
I set the regulatory domain...
root@AP:~# cat  /etc/default/crda
# Set REGDOMAIN to a ISO/IEC 3166-1 alpha2 country code so that iw(8) may set
# the initial regulatory domain setting for IEEE 802.11 devices which operate
# on this system.
# Governments assert the right to regulate usage of radio spectrum within
# their respective territories so make sure you select a ISO/IEC 3166-1 alpha2
# country code suitable for your location or you may infringe on local
# legislature. See `/usr/share/zoneinfo/zone.tab' for a table of timezone
# descriptions containing ISO/IEC 3166-1 alpha2 country codes.
REGDOMAIN=BG
root@AP:~# iw reg get
global
country BG: DFS-ETSI
        (2402 - 2482 @ 40), (N/A, 20), (N/A)
        (5170 - 5250 @ 80), (N/A, 23), (N/A), AUTO-BW
        (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW
        (5490 - 5710 @ 160), (N/A, 27), (0 ms), DFS
        (5725 - 5875 @ 80), (N/A, 14), (N/A)
        (57000 - 66000 @ 2160), (N/A, 40), (N/A), NO-OUTDOOR
phy#0
country US: DFS-FCC
        (2402 - 2472 @ 40), (N/A, 30), (N/A)
        (5250 - 5330 @ 80), (N/A, 23), (0 ms), DFS, AUTO-BW
        (5490 - 5730 @ 160), (N/A, 23), (0 ms), DFS
        (5735 - 5835 @ 80), (N/A, 30), (N/A)
        (57240 - 63720 @ 2160), (N/A, 40), (N/A)
root@AP:~# iwlist wlp0s0  frequency
wlp0s0    32 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 36 : 5.18 GHz
          Channel 40 : 5.2 GHz
          Channel 44 : 5.22 GHz
          Channel 48 : 5.24 GHz
          Channel 52 : 5.26 GHz
          Channel 56 : 5.28 GHz
          Channel 60 : 5.3 GHz
          Channel 64 : 5.32 GHz
          Channel 100 : 5.5 GHz
          Channel 104 : 5.52 GHz
          Channel 108 : 5.54 GHz
          Channel 112 : 5.56 GHz
          Channel 116 : 5.58 GHz
          Channel 120 : 5.6 GHz
          Channel 124 : 5.62 GHz
          Channel 128 : 5.64 GHz
          Channel 132 : 5.66 GHz
          Channel 136 : 5.68 GHz
          Channel 140 : 5.7 GHz
          Channel 149 : 5.745 GHz
          Channel 153 : 5.765 GHz
I tested all available frequencies in 5Ghz, but only works in 30 and 44 channels. And now I do not know what to do?
Those of 100 to 140 are very tempting because of 160 Mhz flame.
P.S.  I use wifi card WLE900VX with 3 inbox antennas uder 5 dbm 2.4/5Ghz.  I have 2 identical devices at a distance of 4 meters across a brick wall and a test of 36 and 44 channels can achieve the following speeds:
iperf3 -c  172.24.1.1 -P 16
[SUM]   0.00-10.01  sec   237 MBytes   199 Mbits/sec    0             sender
[SUM]   0.00-10.01  sec   211 MBytes   177 Mbits/sec                  receiver
look at cfg80211 in your messages...
root@AP:~#  dmesg | grep cfg80211
[    5.463292] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.509242] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.511853] cfg80211: failed to load regulatory.db
the last row has bothered me
root@AP:~# apt-get install wireless-regdb
wireless-regdb is already the newest version (2016.06.10-1).
root@AP:~# dpkg -L wireless-regdb
/lib
/lib/crda
/lib/crda/regulatory.bin
/usr
/usr/share
/usr/share/doc
/usr/share/doc/wireless-regdb
/usr/share/doc/wireless-regdb/changelog.Debian.gz
/usr/share/doc/wireless-regdb/copyright
/usr/share/man
/usr/share/man/man5
/usr/share/man/man5/regulatory.bin.5.gz
Missing expected rows:
/lib/firmware
/lib/firmware/regulatory.db
/lib/firmware/regulatory.db.p7s
For this problem, I found a solution that works for me at the end of:
https://forums.kali.org/showthread.php?40049-platform-regulatory-0-firmware-failed-to-load-regulatory-db-(-2)-Error
BUT USE OTHER CHANNELS IS FAIL
Do an iw list - this should query the card thru the driver...
For example...
$ iw list
Wiphy phy0
	max # scan SSIDs: 20
	max scan IEs length: 422 bytes
	max # sched scan SSIDs: 20
	max # match sets: 11
	max # scan plans: 2
	max scan plan interval: 65535
	max scan plan iterations: 254
	Retry short limit: 7
	Retry long limit: 4
	Coverage class: 0 (up to 0m)
	Device supports RSN-IBSS.
	Device supports AP-side u-APSD.
	Device supports T-DLS.
	Supported Ciphers:
		* WEP40 (00-0f-ac:1)
		* WEP104 (00-0f-ac:5)
		* TKIP (00-0f-ac:2)
		* CCMP-128 (00-0f-ac:4)
		* CMAC (00-0f-ac:6)
	Available Antennas: TX 0 RX 0
	Supported interface modes:
		 * IBSS
		 * managed
		 * AP
		 * AP/VLAN
		 * monitor
		 * P2P-client
		 * P2P-GO
		 * P2P-device
	Band 1:
		Capabilities: 0x11ef
			RX LDPC
			HT20/HT40
			SM Power Save disabled
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			Max AMSDU length: 3839 bytes
			DSSS/CCK HT40
		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
		Minimum RX AMPDU time spacing: 4 usec (0x05)
		HT Max RX data rate: 300 Mbps
		HT TX/RX MCS rate indexes supported: 0-15
		Bitrates (non-HT):
			* 1.0 Mbps
			* 2.0 Mbps (short preamble supported)
			* 5.5 Mbps (short preamble supported)
			* 11.0 Mbps (short preamble supported)
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 2412 MHz [1] (22.0 dBm)
			* 2417 MHz [2] (22.0 dBm)
			* 2422 MHz [3] (22.0 dBm)
			* 2427 MHz [4] (22.0 dBm)
			* 2432 MHz [5] (22.0 dBm)
			* 2437 MHz [6] (22.0 dBm)
			* 2442 MHz [7] (22.0 dBm)
			* 2447 MHz [8] (22.0 dBm)
			* 2452 MHz [9] (22.0 dBm)
			* 2457 MHz [10] (22.0 dBm)
			* 2462 MHz [11] (22.0 dBm)
			* 2467 MHz [12] (22.0 dBm)
			* 2472 MHz [13] (22.0 dBm)
			* 2484 MHz [14] (disabled)
	Band 2:
			RX LDPC
			HT20/HT40
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			DSSS/CCK HT40
		VHT Capabilities (0x039071b0):
			Max MPDU length: 3895
			Supported Channel Width: neither 160 nor 80+80
			RX LDPC
			short GI (80 MHz)
			TX STBC
			SU Beamformee
			MU Beamformee
		VHT RX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
			3 streams: not supported
			4 streams: not supported
			5 streams: not supported
			6 streams: not supported
			7 streams: not supported
			8 streams: not supported
		VHT RX highest supported: 0 Mbps
		VHT TX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
		VHT TX highest supported: 0 Mbps
		Bitrates (non-HT):
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 5180 MHz [36] (22.0 dBm)
			* 5200 MHz [40] (22.0 dBm)
			* 5220 MHz [44] (22.0 dBm)
			* 5240 MHz [48] (22.0 dBm)
			* 5260 MHz [52] (22.0 dBm) (no IR, radar detection)
			* 5280 MHz [56] (22.0 dBm) (no IR, radar detection)
			* 5300 MHz [60] (22.0 dBm) (no IR, radar detection)
			* 5320 MHz [64] (22.0 dBm) (no IR, radar detection)
			* 5340 MHz [68] (disabled)
			* 5360 MHz [72] (disabled)
			* 5380 MHz [76] (disabled)
			* 5400 MHz [80] (disabled)
			* 5420 MHz [84] (disabled)
			* 5440 MHz [88] (disabled)
			* 5460 MHz [92] (disabled)
			* 5480 MHz [96] (disabled)
			* 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
			* 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
			* 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
			* 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
			* 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
			* 5600 MHz [120] (22.0 dBm) (no IR, radar detection)
			* 5620 MHz [124] (22.0 dBm) (no IR, radar detection)
			* 5640 MHz [128] (22.0 dBm) (no IR, radar detection)
			* 5660 MHz [132] (22.0 dBm) (no IR, radar detection)
			* 5680 MHz [136] (22.0 dBm) (no IR, radar detection)
			* 5700 MHz [140] (22.0 dBm) (no IR, radar detection)
			* 5720 MHz [144] (22.0 dBm) (no IR, radar detection)
			* 5745 MHz [149] (22.0 dBm)
			* 5765 MHz [153] (22.0 dBm)
			* 5785 MHz [157] (22.0 dBm)
			* 5805 MHz [161] (22.0 dBm)
			* 5825 MHz [165] (22.0 dBm)
			* 5845 MHz [169] (disabled)
			* 5865 MHz [173] (disabled)
			* 5885 MHz [177] (disabled)
			* 5905 MHz [181] (disabled)
	Supported commands:
		 * new_interface
		 * set_interface
		 * new_key
		 * start_ap
		 * new_station
		 * new_mpath
		 * set_mesh_config
		 * set_bss
		 * authenticate
		 * associate
		 * deauthenticate
		 * disassociate
		 * join_ibss
		 * join_mesh
		 * remain_on_channel
		 * set_tx_bitrate_mask
		 * frame
		 * frame_wait_cancel
		 * set_wiphy_netns
			 * set_channel
		 * set_wds_peer
		 * tdls_mgmt
		 * tdls_oper
		 * start_sched_scan
		 * probe_client
		 * set_noack_map
		 * register_beacons
		 * start_p2p_device
		 * set_mcast_rate
		 * connect
		 * disconnect
		 * channel_switch
		 * set_qos_map
		 * add_tx_ts
		 * set_multicast_to_unicast
	Supported TX frame types:
		 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
	Supported RX frame types:
		 * IBSS: 0x40 0xb0 0xc0 0xd0
		 * managed: 0x40 0xd0
		 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * mesh point: 0xb0 0xc0 0xd0
		 * P2P-client: 0x40 0xd0
		 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * P2P-device: 0x40 0xd0
	WoWLAN support:
		 * wake up on disconnect
		 * wake up on magic packet
		 * wake up on pattern match, up to 20 patterns of 16-128 bytes,
		   maximum packet offset 0 bytes
		 * can do GTK rekeying
		 * wake up on GTK rekey failure
		 * wake up on EAP identity request
		 * wake up on 4-way handshake
		 * wake up on rfkill release
		 * wake up on network detection, up to 11 match sets
		 * wake up on TCP connection
	software interface modes (can always be added):
		 * AP/VLAN
		 * monitor
	valid interface combinations:
		 * #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
		   total <= 3, #channels <= 2
	HT Capability overrides:
		 * MCS: ff ff ff ff ff ff ff ff ff ff
		 * maximum A-MSDU length
		 * supported channel width
		 * short GI for 40 MHz
		 * max A-MPDU length exponent
		 * min MPDU start spacing
	Device supports TX status socket option.
	Device supports HT-IBSS.
	Device supports SAE with AUTHENTICATE command
	Device supports low priority scan.
	Device supports scan flush.
	Device supports per-vif TX power setting
	P2P GO supports CT window setting
	P2P GO supports opportunistic powersave setting
	Driver supports full state transitions for AP/GO clients
	Driver supports a userspace MPM
	Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
	Device adds DS IE to probe requests
	Device can update TPC Report IE
	Device supports static SMPS
	Device supports dynamic SMPS
	Device supports WMM-AC admission (TSPECs)
	Device supports configuring vdev MAC-addr on create.
	Device supports TDLS channel switching
root@AP:~# iw list | less
Wiphy phy0
        max # scan SSIDs: 16
        max scan IEs length: 195 bytes
        max # sched scan SSIDs: 0
        max # match sets: 0
        max # scan plans: 1
        max scan plan interval: -1
        max scan plan iterations: 0
        Retry long limit: 4
        Supported Ciphers:
                * TKIP (00-0f-ac:2)
                * CMAC (00-0f-ac:6)
                * CMAC-256 (00-0f-ac:13)
                * GMAC-128 (00-0f-ac:11)
                * GMAC-256 (00-0f-ac:12)
        Available Antennas: TX 0x7 RX 0x7
        Configured Antennas: TX 0x7 RX 0x7
                 * managed
                 * AP
                 * monitor
                 * mesh point
        Band 1:
                Capabilities: 0x19ef
                        RX LDPC
                        HT20/HT40
                        RX HT20 SGI
                        RX HT40 SGI
                        TX STBC
                        RX STBC 1-stream
                        Max AMSDU length: 7935 bytes
                        DSSS/CCK HT40
                Minimum RX AMPDU time spacing: 8 usec (0x06)
                HT TX/RX MCS rate indexes supported: 0-23
                Bitrates (non-HT):
                        * 1.0 Mbps
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 2412 MHz [1] (20.0 dBm)
                        * 2417 MHz [2] (20.0 dBm)
                        * 2422 MHz [3] (20.0 dBm)
                        * 2427 MHz [4] (20.0 dBm)
                        * 2432 MHz [5] (20.0 dBm)
			* 2437 MHz [6] (20.0 dBm)
                        * 2442 MHz [7] (20.0 dBm)
                        * 2447 MHz [8] (20.0 dBm)
                        * 2452 MHz [9] (20.0 dBm)
                        * 2457 MHz [10] (20.0 dBm)
                        * 2462 MHz [11] (20.0 dBm)
                        * 2467 MHz [12] (disabled)
                        * 2472 MHz [13] (disabled)
        Band 2:
                        RX LDPC
                        HT20/HT40
                        RX HT20 SGI
                        RX HT40 SGI
                        TX STBC
                        RX STBC 1-stream
                        DSSS/CCK HT40
                VHT Capabilities (0x338001b2):
                        Max MPDU length: 11454
                        RX LDPC
                        short GI (80 MHz)
                        TX STBC
                        RX antenna pattern consistency
                        TX antenna pattern consistency
                VHT RX MCS set:
                        1 streams: MCS 0-9
                        2 streams: MCS 0-9
                        3 streams: MCS 0-9
                VHT TX MCS set:
                        1 streams: MCS 0-9
                        2 streams: MCS 0-9
                        3 streams: MCS 0-9
                Bitrates (non-HT):
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 5180 MHz [36] (23.0 dBm)
			* 5200 MHz [40] (23.0 dBm)
                        * 5220 MHz [44] (23.0 dBm)
                        * 5240 MHz [48] (23.0 dBm)
                        * 5260 MHz [52] (20.0 dBm) (radar detection)
                        * 5280 MHz [56] (20.0 dBm) (radar detection)
                        * 5300 MHz [60] (20.0 dBm) (radar detection)
                        * 5320 MHz [64] (20.0 dBm) (radar detection)
                        * 5500 MHz [100] (23.0 dBm) (radar detection)
                        * 5520 MHz [104] (23.0 dBm) (radar detection)
                        * 5540 MHz [108] (23.0 dBm) (radar detection)
                        * 5560 MHz [112] (23.0 dBm) (radar detection)
                        * 5580 MHz [116] (23.0 dBm) (radar detection)
                        * 5600 MHz [120] (23.0 dBm) (radar detection)
                        * 5620 MHz [124] (23.0 dBm) (radar detection)
                        * 5640 MHz [128] (23.0 dBm) (radar detection)
                        * 5660 MHz [132] (23.0 dBm) (radar detection)
                        * 5680 MHz [136] (23.0 dBm) (radar detection)
                        * 5700 MHz [140] (23.0 dBm) (radar detection)
                        * 5720 MHz [144] (disabled)
                        * 5745 MHz [149] (14.0 dBm)
                        * 5765 MHz [153] (14.0 dBm)
                        * 5785 MHz [157] (14.0 dBm)
                        * 5805 MHz [161] (14.0 dBm)
                        * 5825 MHz [165] (14.0 dBm)
        Supported commands:
                 * new_interface
                 * set_interface
                 * new_key
                 * start_ap
                 * new_station
                 * new_mpath
                 * set_mesh_config
                 * set_bss
                 * authenticate
                 * associate
                 * deauthenticate
                 * disassociate
                 * join_ibss
                 * join_mesh
                 * remain_on_channel
                 * frame
                 * frame_wait_cancel
                 * set_wiphy_netns
                 * set_channel
                 * set_wds_peer
                 * probe_client
                 * set_noack_map
                 * register_beacons
                 * start_p2p_device
                 * set_mcast_rate
                 * connect
                 * disconnect
                 * channel_switch
                 * set_qos_map
                 * Unknown command (121)
                 * monitor
                 * #{ AP, mesh point } <= 8, #{ managed } <= 1,
                   total <= 8, #channels <= 1, STA/AP BI must match, radar detect widths: { 20 MHz (no HT), 20 MHz, 40 MHz, 80 MHz }
        Device supports AP scan.
        Device supports VHT-IBSS.
thanks sfx2000
I just put a short sheet on the frequencies above. Here is the full sheet. Do you see anything worrying that limits me only to channels 36 and 44?
Seems like your wireless-regdb is out of date... check your UNII-3 levels, and they're way off...
apt list wireless-regdb
wireless-regdb/bionic-updates,bionic-updates,now 2018.05.09-0ubuntu1~18.04.1 all [installed]
wireless-regdb/bionic,bionic 2016.06.10-0ubuntu1 all
You want the more recent dpkg from 2018.05.09
Forget which driver, but I'm assuming this card is either ath9k or ath10k, so do check that as well... I'm going to assume however, that DFS for hostapd is likely not available for this card, as this involves extensive testing for FCC and EU RE-D certs, which is usually something done if fully integrated into a final product where the whole product is tested.
The only other advise I can give is to ensure that your uBoot is current for your board revision, and that you doublecheck the driver that is loaded (along with the wireless-regdb package I mentioned above)
And just note that eBin had issues with earlier revisions and the mPCI-e slot, so just keep that in mind...
tnx
Change Stretch to Bionic. I have newest wireless-regdb
root@espressobin:~# apt-get install wireless-regdb
Reading package lists... Done
Building dependency tree
wireless-regdb is already the newest version (2018.05.09-0ubuntu1~18.04.1).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
However, the problem remains the same. I create APs only at 36 and 44.
I think the limitations are due to the limitations of  phy#0
Any ideas for change phy#0 country code?
root@espressobin:~# iw reg get
global
phy#0
country US: DFS-FCC
31 minutes ago, sfx2000 said:
If you do a client scan with the card, do you see AP's in the other 5GHz channels?
Hard Not visible AP
See the result of the command:
root@espressobin:/# iw wlp0s0 info
Interface wlp0s0
        ifindex 9
        wdev 0x1
        addr 04:f0:21:38:c7:3b
        ssid ARMBIAN
        type AP
        wiphy 0
        channel 44 (5220 MHz), width: 80 MHz, center1: 5210 MHz
        txpower 23.00 dBm
change channel=48 on /etc/hostapd.conf
root@espressobin:/# /etc/init.d/hostapd restart
[ ok ] Restarting hostapd (via systemctl): hostapd.service.
Interface wlp0s0
        ifindex 9
        wdev 0x1
        type managed
        wiphy 0
        txpower 23.00 dBm
type NOT AP on cannel 48
40 minutes ago, sfx2000 said:
That's odd - hmmm.... wondering if this is Atheros and one-time programmable memory...
Check with the card vendor - everything looks ok, and you've done all the right steps so far...
After reading I found this link
https://wireless.wiki.kernel.org/en/developers/Regulatory/CRDA
there is a paragraph that describes my exact case
"As an example if your device was programmed for operation in the US which allows operation on channels 1-11 on the 2.4 GHz band and you visit Japan which allows operation on channels 1-14 and you change your regulatory domain to JP you will not be able to use channel 12, 13 or 14 (CCK). But if you have a device programmed for operation in Japan and visit the US and you select US as your regulatory domain you will have channel 12-14 disabled."
My WLE900VX   programmed for operation in the US in eeprom,  I have asked iw reg set BG and in practice I can use the channels that are allowed in the US and BG zones.
root@espressobin:/# iw reg get
global
phy#0
country US: DFS-FCC
I think need to get the driver ath10k to ignore country code in eeprom. For now there I no idea how to achieve it.
P.S.  I found a solution to the problem I have formulated
https://sites.google.com/site/twisteroidambassador/linux/ath-user-regd
But now I have another problem, I do not know how to do the actions on the link for Armbian.
I think part of the challenge here is that the kernel drivers with patches might say "ok" with settings, but not actually work...
I've personally seen this with broadcom, and I'm thinking QCA might be doing the same thing... if this is the case, then the patches you mention above just won't work if the card is configured for hostapd if one wants to override the reg_domain...
It'll be fine as a client sta....
