Peter Hudak Posted December 28, 2018 Share Posted December 28, 2018 Hello, I can't boot my new OrangePi One v.1.1. I have used various SD cards including Sandisk Ultra 32GB. On the serial console I every time see: U-Boot SPL 2018.05-armbian (Oct 26 2018 - 22:09:12 +0200) DRAM: 512 MiB Trying to boot from MMC1 MMC Device 0 not found spl: could not find mmc device. error: -19 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Power supply is 5V 3A. Ethernet is unplugged and nothing is connected to USB. What I tried: - Flashed on two different computers (MAC and Windows) - used both etcher and dd - checked cards with h2testw for errors (no errors found) - formatted cards using SD card formatter (full format) - checked checksums of downloaded images (all OK) - tried all downloadable images for the board, including an ancient raspbian from orangepi.org. Android did not boot either. To me it seems the board has something new on it that is not recognised by driver or there is a hardware issue with the OrangePi One. One of the cards was working fine in RaspberryPi. I'd appreciate if you give me advice how to build a brand new bootloader from source and flash it, just to see if I get past the "error: -19". thank you Link to comment Share on other sites More sharing options...
guidol Posted December 28, 2018 Share Posted December 28, 2018 1 hour ago, Peter Hudak said: I can't boot my new OrangePi One v.1.1. I have tried with all downloadable images from Armbian as well as an ancient image from orangepi.org. Flashed with Etcher and dd. Power supply is 5V 3A. Ethernet is unplugged and nothing is connected to USB. To me it seems the board has something new on it that is not recognised by driver or there is a hardware issue with the OrangePi One. One of the cards was working fine in RaspberryPi. I got 5 OPi One v1.1 since a year and all of them do boot armbian from a 16GB Sandisk Ultra (up to 80MB/sec read - Class 10). They als do boot my selfbuild (via the armbian-build-system) acutal dev version: Armbian_5.67_Orangepizero_Debian_stretch_dev_4.19.11.img Some SBC does have hardware-problems with the hardware-detection of the sdcard (connection inside the MicroSD-Slot fails) - and your u-boot log does show that the board didnt found MMC0 and MMC1 One of mine OPi One does show these lines - before starttig the kernel. see the lines in the hidden section below: Spoiler U-Boot SPL 2017.11-armbian (Apr 20 2018 - 12:19:20) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2017.11-armbian (Apr 20 2018 - 12:19:20 +0300) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3708 bytes read in 243 ms (14.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 201 bytes read in 198 ms (1000 Bytes/s) 5097109 bytes read in 595 ms (8.2 MiB/s) 6972808 bytes read in 772 ms (8.6 MiB/s) Found mainline kernel configuration 32002 bytes read in 1792 ms (16.6 KiB/s) 4179 bytes read in 1263 ms (2.9 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5097045 Bytes = 4.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 49b23000, end 49fff655 ... OK reserving fdt memory region: addr=43000000 size=6e000 Loading Device Tree to 49ab2000, end 49b22fff ... OK Starting kernel ... You did download the images from here? (and unzipped they before flashing?) https://dl.armbian.com/orangepione/archive/ https://dl.armbian.com/orangepione/archive/Armbian_5.65_Orangepione_Debian_stretch_next_4.14.78.7z Did you enable the verify in the etcher options? Link to comment Share on other sites More sharing options...
Peter Hudak Posted December 28, 2018 Author Share Posted December 28, 2018 I have downloaded images from https://dl.armbian.com/orangepione/ and etched using the verify function, etcher also said it was verified. I tried the latest version from https://dl.armbian.com/orangepione/Debian_stretch_next.7z as well as https://dl.armbian.com/orangepione/archive/Armbian_5.59_Orangepione_Debian_stretch_next_4.14.65.7z . I have not used the 4.14.78 version but I will give it a try. Sure I have unzipped them and compared the checksums. After reading your output I see that I don't get to your line #4. I'd like to try out your build Armbian_5.67_Orangepizero_Debian_stretch_dev_4.19.11, where can I get it? Link to comment Share on other sites More sharing options...
martinayotte Posted December 28, 2018 Share Posted December 28, 2018 8 minutes ago, Peter Hudak said: After reading your output I see that I don't get to your line #4. If your issue is having a "broken sd card detect" , check my post here as a workaround : Link to comment Share on other sites More sharing options...
Peter Hudak Posted December 28, 2018 Author Share Posted December 28, 2018 @martinayotte I'm afraid I won't be able to build the system on my mac right now, I will try to do it on RaspberryPi tomorrow. However I like the "soldering pin to ground" option better (I will not solder it right away, just connect it to the ground to see if it has any impact). I will try to find what to connect tomorrow as it is not straightforward. Link to comment Share on other sites More sharing options...
guidol Posted December 28, 2018 Share Posted December 28, 2018 ...but ifI hadnt a card in the MicroSD-slot of my OPi One it didnt show any information - also no u-boot sign of life Link to comment Share on other sites More sharing options...
martinayotte Posted December 29, 2018 Share Posted December 29, 2018 16 hours ago, Peter Hudak said: I will try to find what to connect tomorrow as it is not straightforward. The CD pin is the pin 9. 16 hours ago, Peter Hudak said: I'm afraid I won't be able to build the system You don't need to build everything, you only need to have DTC compiler, decompile the file /boot/dtb/sun8i-h3-orangepi-lite.dtb from SDCard into DTS, edit it to remove "cd-gpio" and add "cd-broken", and recompile it into DTB. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted December 29, 2018 Share Posted December 29, 2018 6 minutes ago, martinayotte said: You don't need to build everything, you only need to have DTC compiler, decompile the file /boot/dtb/sun8i-h3-orangepi-lite.dtb from SDCard into DTS, edit it to remove "cd-gpio" and add "cd-broken", and recompile it into DTB. Changing DT will have no effect this early (in SPL), SPL relies on CONFIG_MMC0_CD_PIN configuration option. And at least previous versions printed "mmc: no card present" when trying to access a card with broken CD pin. Link to comment Share on other sites More sharing options...
martinayotte Posted December 29, 2018 Share Posted December 29, 2018 1 minute ago, zador.blood.stained said: Changing DT will have no effect this early (in SPL), SPL relies on CONFIG_MMC0_CD_PIN configuration option. You're right ! ... I was forgetting that my recipe works only if the DT of the U-Boot is edited and then U-Boot recompiled. Link to comment Share on other sites More sharing options...
