christopher Posted December 29, 2018 Share Posted December 29, 2018 I am wanting to do bare programming of the A20. Does anyone have a memory map of the A20? I understand there are three types of memory used in the A20, including onboard non changeable memory. Does anyone have a quick description of the memory banks available - location, programmability, access? Christopher Link to comment Share on other sites More sharing options...
Solution martinayotte Posted December 29, 2018 Solution Share Posted December 29, 2018 9 hours ago, christopher said: I am wanting to do bare programming of the A20. Starting to do Bare Metal programming isn't a easy task ... You will need to learn a tons of things, you need to start here : http://linux-sunxi.org/A20 Then here : http://linux-sunxi.org/EGON and http://linux-sunxi.org/BROM Good luck ! Link to comment Share on other sites More sharing options...
christopher Posted December 29, 2018 Author Share Posted December 29, 2018 Thanks Martin. It is the paucity of information that is the hardest! I'll follow these up and thanks again Christopher. Link to comment Share on other sites More sharing options...
