overlayroot cannot modify /media/root-ro
mzakharo
Hi,
I am running OrangePI lite with 5.65 Xenial. I followed tutorial on using overlayroot here "How to freeze your filesystem". However, when I run overlayroot-chroot to make changes, I am getting the following error when I modify files: "Read-only file system".  Here is output of 'mount':
/dev/mmcblk0p1 on / type ext4 (ro,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=50696k,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
I tried running mount to make it read-write:
 mount -o remount,rw /dev/mmcblk0p1
#make changes, revert back
 mount -o remount,ro /dev/mmcblk0p1
While this works, when I exit overlayroot-chroot, my system's filesystem is stuck in Read-Only mode
 Any ideas on what I am doing wrong?
Ok, so the best way of working with the system I have found is to run "overlayroot-chroot + mount -o remount,rw /dev/mmcblk0p1" to modify /etc/overlayroot.conf and disable overlayroot and reboot; then make changes; then re-enable overlayroot in the conf file and reboot. Very cumbersome; Is there a better way?
