[Development] RK3399 media script
JMCC
THE MEDIA SCRIPT IS DEPRECATED, IN FAVOR OF THE LEGACY MULTIMEDIA INTEGRATION. PLEASE REFER TO THIS TOPIC:
So finally we have the first version of:
The UN-official, UN-supported, etc...
RK3399 MEDIA TESTING SCRIPT
This is the first release of the RK3399 media testing script. The script provides a functionality similar to its RK3288 equivalent:
  • Installing all the libraries and system configurations necessary for GPU accelerated X desktop, Chromium WebGL, full VPU video play acceleration up to 4k@60 10-bit HEVC (the maximum supported by the SoC), and GLES 3.2 / OpenCL 1.2 support.
  • Three video players supporting full VPU acceleration (RKMPP) and KMS display (GBM or a X11 DRM "hack", as described by the authors), namely: MPV, Gstreamer and Kodi.
  • Two example programs using the OpenCL functionality: Examples form the Arm Compute Library, and a GPU crypto miner (an old version, but small and simple).
  • A library that will act as an OpenGL to OpenGL-ES wrapper, allowing you to run programs that use OpenGL 1.5-2.0.
  • Two additional features, that have no big interest from the Armbian development prospective, but I find them interesting to play with:
    •  Chromium browser with support for Flash and DRM-protected commercial web video streaming (tested with Amazon Prime, should also work with Netflix, Hulu, etc.),
    • and a simple Pulseaudio GTK equalizer using LADSPA.
Here is a more thorough documentation:
Spoiler
ARMBIAN UNOFFICIAL RK3399 MEDIA TESTING SCRIPT
v1.0 Bionic - 2019/01/11
This script will install several multimedia-related software pieces in a
RK3399 Ubuntu Bionic Armbian desktop default image (kernel 4.4.y).
Currently it only supports the installation of the features, while
uninstall must be performed manually.
The script must be run in a command line from the same directory it was
unpacked (./media-rk3399.sh), and will ask for superuser privileges if
not launched with "sudo". Each subfolder contains, in addition to the
packages needed for installation, a text file with information about the
sources for those packages.
The script will present the user with a menu where they can select the
features to be installed. Here is a brief description of each option:
- System: This option will install the base libraries, X server packages
          and system files configuration. It must be run at least once
          before installing any of the other features, or after any
          system upgrade that modified X or Chromium configuration.
          Enabling system config will also present the user with the
          choice of two different versions of the Rockchip X server:
            · Glamor: The tweaked X server that you can download from
              Rockchip repos, with a few additional tweaks. It will use
              Glamor for GPU acceleration, providing good 3D performance
              and complete vsync, but giving a very laggy experience in
              general desktop usage.
            · Armsoc: An updated version of the xf86 Armsoc driver. It
              only supports fullscreen vsync, but on the other hand the
              overall desktop experience is much snappier.
- Devel: When this option is enabled, the script will install the
         development libraries for every other option that is selected.
         So, for example, if in your first run of the script you keep
         this option disabled and enable the rest, it will install all
         the features but without any devel lib. If eventually you need,
         e.g., to compile some app requiring Gstreamer development libs,
         then you can run again the script, and select only "Devel" and
         "Gstreamer", so in that run it will only install Gstreamer with
         the development libraries, without touching the rest.
- MPV: This is a RKMPP accelerated version of MPV. In order to use the
       hardware acceleration, it needs to make use of KMS for display,
       which means that it will ignore the X server if it is running,
       and play video in a full-screen overlay, using keyboard or LIRC
       to control the player. Type "man mpv" for a list of keyboard
       controls (tip: shift+Q will save position and exit).
       Alternatively, you can also use software decoding, and output to
       a X window with mouse support. It will still have some display
       acceleration through X11/EGL, though not as efficient as GBM/KMS.
         · To use the X, non-RKMPP version, just type "mpv <file>" in
           the console, or use the launcher labeled simply "MPV".
         . To use the GBM+RKMPP version, type "mpv-gbm <file>", or use
           the "MPV (GBM)" launcher.
         · You can use the player even in a console-only session.
- Gstreamer: These are the Rockchip Gstreamer plugins for media playback
             and capture.
             Notice that the Gstreamer plugin is the only method that
             allows full RKMMP+KMS acceleration associated to a X
             window.
               · To play a video in a X session, use the launcher "Rock-
                 chip Gst Player".
               . From the command line, in a X session, type:
                 "gst-play-1.0 --videosink=rkximagesink <file>"
               . From a console-only session, type:
                 "gst-play-1.0 --videosink=kmssink <file>"
- CLSamples: A couple of simple programs to test OpenCL capabilities:
	     · Compiled examples from the Arm Compute Library
	     . An old GPU crypto miner (cgminer) with support for
	       extra algorythms like Skein.
	     They are installed under ~/clsamples, where you can find
	     a readme.txt file with instructions.
- GL4ES: An Opengl-ES wrapper library that will allow you to use OpenGL
         1.5-2.0 compatible programs with hardware acceleration.
         More info: https://github.com/ptitSeb/gl4es.
         · In order to make it easier to use the library, we have
           included a script called "glrun", that will set the proper
           environment variables. Launch your OpenGL program like this:
           "glrun <command>"
- Streaming: This will install Chromium with the Widevine DRM and
             Pepper-Flash libraries enabled, allowing you to watch
             videos from sites such as Netflix, Amazon Prime or Hulu.
             It will also install the h264ify addon, which will force
             all Youtube videos to use the H.264 codec.
             Since those libraries are only available for 32-bit ARM,
             the script will install a whole armhf docker container,
             with a minimal ubuntu and Chromium installation on it. It
             will also install a wrapper for running commands inside the
             docker container called "armhf-run":
               · Type "armhf-run chromium-browser" to launch the 32-bit
                 Chromium in regular mode.
               . Type "armhf-run chromium-streaming" to launch it in
                 streaming mode (may cause problems with non-streaming
                 webpages).
             The script will also install desktop entries for both
             options.
- Equalizer: A GTK-based equalizer for PulseAudio, using LADSPA. You
             need to enable it through the menu entry, and select the
             desired preset or tweak your own settings. The "Boosted"
             preset is recommended for everyday use.
             This package is old and unmaintained, but I still find it
             useful.
- Kodi: Kodi 18.0 Leia rc4. This version is supposed to be stable
        enough for normal use. But the main purpose of including Kodi in
        the script is to test the new RKMPP+KMS implementation. We don't
        intend to offer a full-fledged distribution of Kodi. For that, I
        recommend using LibreELEC.
        It cannot be launched from an active X session, you need to
        switch to a virtual terminal and stop the X server first.
        · The "Kodi" desktop launcher will do the whole process for you.
        · From the command line, in a X session, type:
          "kodi-gbm-wrapper" for the same effect.
        · If you are already in a console-only session, you can just
          type "kodi".
All the RKMPP accelerated players can handle up to 4K@60 10-bit HEVC
with perfect smoothness. 4K VP9 8-bit is fine, but don't try
VP9 10-bit or you'll get a green screen and your /var/log partition
filled up in less than ten seconds ;)
Please report bugs and suggestions in the thread dedicated to this
script at the Armbian Forum. Enjoy!
JMCC.
>>> DOWNLOAD LINK <<<
Prerequisites:
  • You need a fresh Armbian Bionic desktop image with legacy kernel installed.
Instructions:
  1. Download the file above
  2. Untar it: tar xvf media-rk3399_*.txz
  3. cd media-script
  4. ./media-rk3399.sh
Notes:
  • This script is not officially supported by the Armbian project. It is just a community effort to help the development of the main build, by experimenting with a possible implementation of the media capabilities of this particular SoC.
  • Therefore, questions about the script should not be laid out as support requests, but as commentaries or community peer-to-peer assistance.
  • That being said, all commentaries/suggestions/corrections are very welcome. In the same way, I will do my best to help solve any difficulty that may arise regarding the script.
Enjoy!
  • JMCC featured, pinned and unfeatured this topic
Congratulations, good job. I ran the script on Khadas EDGE on the latest SERVER image (5.69 20190111). Installed all components. Launched KODI, it works with HW and plays all my test files (including 4K). In the near future I will check the script in the environment x11 (DE XFCE). :)
Installed the script on the system with DE XFCE. The screen resolution is 1920x1080 (1080p), this is the maximum that the current test monitor supports. Test video from MPV-works immediately in full screen without brakes, but there is no possibility to control it (perhaps there are buttons on the keyboard to control ?). Web browser. Tried all the options from 720 to 4K-everything works in full screen without brakes. For 4K-not enough of my channel on the Internet, is buffering, but it has nothing to do with HW video. When trying to start KODI from under XFCE (x11), issued a warning about closing X11, switched to the console, but did not start (with a message about not being able to create a GUI). I'm probably running KODI wrong to x11 ?
Yes, it runs fulscreen with no mouse support. You can control it with a remote control via LIRC, or with the keyboard. Arrows, space, Q for quit and shift-Q for save position and quit. "man mpv" will give you the whole list of controls.
Well, the wrapper is a very basic implementation, meant to stop nodm, which is the default Armbian DM. If you are using lightdm instead, you must edit the file "/usr/local/bin/kodi-gbm-wrapper"
Or just do it manually: Ctrl+alt+F1, "sudo service lightdm stop", "kodi"
Isn't it possible to build desktop link that will open terminal? With this it should have mouse support?
That's actually what the script currently does. In the documentation you can find more info about how it works.
You can choose either X11 ( windowed, mouse support, worst performance) and GBM (writes directly to display without using the X server, no mouse support, best performance).
I was very pleased with Gstreamer. ON 4K TV, you can scale any video to any size on your desktop. (now can use any player or write your own).  :)
Now I test different videos in MPV Gstreamer KODI and browser on TV 4K (4096х2160), impressive performance RK3399 . :)
It looks like system update of Armbian_5.69_Nanopim4_Ubuntu_bionic_default_4.4.167_desktop.img make it freeze(when X11 already loaded, but XFCE not yet appear). Board is Friendlyarm NanoPi M4/2GB/SD.
without update everything is OK.
does anybody have similar behavior?
Edited by ayaromenok
I just tried the script on a RockPi 4B, running the version of Armbian available here: https://wiki.radxa.com/Rockpi4/downloads
When I tried to run the install script, it failed with an error saying that there is a conflict with Armbian's version of libgles2 and the one in libmali-rk-midguard.  The specific verbiage is:
dpkg: regarding .../libmali-rk-midgard-t86x-r14p0-r0p0_1.6-1-0armbian1_arm64.deb containing libmali-rk-midgard-t86x-r14p0-r0p0:arm64:
 libgles2-mesa:arm64 conflicts with libgles2
  libmali-rk-midgard-t86x-r14p0-r0p0:arm64 provides libgles2 and is to be installed.
dpkg: error processing archive packages/libs/libmali-rk-midgard-t86x-r14p0-r0p0_1.6-1-0armbian1_arm64.deb (--unpack):
 conflicting packages - not installing libmali-rk-midgard-t86x-r14p0-r0p0:arm64
Full install log at the bottom of this post.
Note that I tried this against both the stable and the nightly repos - same result either way.  (I didn't expect a different result regardless, but I figured I'd try it for completeness sake.)
Any thoughts on this?  I'm sure I could just use the appropriate flags with dpkg to make the packages install, but that would likely cause all sorts of dependency issues, and might make apt-get misbehave later.
Any advice is appreciated!  Full install log below:
Spoiler
rock@rockpi4b:~/Downloads/media-script$ cat install.log-2019-01-14
Hit:3 http://security.debian.org stretch/updates InRelease
Ign:1 http://cdn-fastly.deb.debian.org/debian stretch InRelease
Hit:2 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease
Hit:6 http://cdn-fastly.deb.debian.org/debian stretch Release
Hit:5 https://apt.armbian.com stretch InRelease
Reading package lists...
* Installing base packages and configuring system *
Installing base libs...
(Reading database ... 65825 files and directories currently installed.)
Preparing to unpack .../libmali-rk-midgard-t86x-gbm-r14p0-r0p0_1.6-1_arm64.deb ...
Unpacking libmali-rk-midgard-t86x-gbm-r14p0-r0p0:arm64 (1.6-1) over (1.6-1) ...
Preparing to unpack .../librockchip-mpp1_20171218-3_arm64.deb ...
Unpacking librockchip-mpp1 (20171218-3) over (20171218-3) ...
Preparing to unpack .../librockchip-vpu0_20171218-3_arm64.deb ...
Unpacking librockchip-vpu0 (20171218-3) over (20171218-3) ...
Preparing to unpack .../rockchip-mpp-demos_20171218-3_arm64.deb ...
Unpacking rockchip-mpp-demos (20171218-3) over (20171218-3) ...
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Errors were encountered while processing:
Building dependency tree...
Reading state information...
Correcting dependencies... Done
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
4 not fully installed or removed.
After this operation, 17.6 MB disk space will be freed.
Removing libmali-rk-midgard-t86x-r14p0-r0p0:arm64 (1.6-1-0armbian1) ...
Setting up librockchip-mpp1 (20171218-3) ...
Setting up libmali-rk-midgard-t86x-gbm-r14p0-r0p0:arm64 (1.6-1) ...
Setting up librockchip-vpu0 (20171218-3) ...
Setting up rockchip-mpp-demos (20171218-3) ...
Configuring X server...
(Reading database ... 65806 files and directories currently installed.)
Preparing to unpack .../xserver-common-rockchip_1.19.3-2armbian1_all.deb ...
Unpacking xserver-common-rockchip (3:1.19.3-2armbian1) over (3:1.19.3-2armbian1) ...
Selecting previously unselected package xserver-xorg-core-rockchip.
Preparing to unpack .../xserver-xorg-core-rockchip_1.19.3-2armbian1_arm64.deb ...
Unpacking xserver-xorg-core-rockchip (3:1.19.3-2armbian1) ...
Selecting previously unselected package xserver-xorg-video-armsoc.
Preparing to unpack .../xserver-xorg-video-armsoc_1.4.1-1_arm64.deb ...
Unpacking xserver-xorg-video-armsoc (1.4.1-1) ...
Processing triggers for man-db (2.7.6.1-2) ...
  xserver-xorg-core-rockchip xserver-xorg-video-armsoc
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 2,517 kB disk space will be freed.
(Reading database ... 65851 files and directories currently installed.)
Removing xserver-xorg-video-armsoc (1.4.1-1) ...
Removing xserver-xorg-core-rockchip (3:1.19.3-2armbian1) ...
Setting up xserver-common-rockchip (3:1.19.3-2armbian1) ...
Configuring Chromium acceleration...
./media-rk3399.sh: line 249: /etc/chromium-browser/default: No such file or directory
Finished.
Edited by Tido
added spoiler - for better reading, please do that yourself next time. thx
If you notice, that download is Armbian with Debian Stretch desktop. The script requires Armbian with Ubuntu Bionic desktop. We (the Armbian project) has not released an official image for Rockpi 4 yet, so you will have to build it yourself using Raxda fork of Armbian (in case it is publicly available), or ask them to build it.
My recommendation would be that you ask in the Raxda forums how to get a ubuntu bionic desktop Armbian image for Rockpi.
Does it also happen if you flash a fresh Armbian_5.69_Nanopim4 image, or only when you upgrade through apt?
Thanks for that, and sorry for the mix-up - not sure how I missed something that basic (different major version IS pretty much the definituon of "the basics"...).  Being said, I can pursue building myself on what i have now, and can share the result if its useful.  And, shoud you decide to do a release for the RockPi 4B, and ya need a tester, I'd be happy to test or help however I can.
Installed on rockpro64 and bash ran flawlessly, everything's seems to have installed and all desktop links created for applications, unfortunately seems that script was unable to override something, all apps run as if nothing had been done no streaming, mpv works same as before and Kodi does close x but breaks system when trying to run kodi, I'll try to upload log scripts 2morrow, hope whatever is missing shows up there.
This release is also meant for the RockPi 4B, as well as for other RK3399 boards. Only requirement is that the system is running Armbian Bionic with 4.4.y kernel. I'm not going to make a release for Debian Stretch, because the Armbian multimedia implementation will be based on Ubuntu Bionic.
only when upgrade through apt update/upgrade.
just check once again - can confirm freeze on this particular board(Friendlyarm NanoPI M4).
in upgrade its already
armbian-bionic-desktop/bionic,bionic 5.70 all [upgradable from: 5.69]
complete list of upgrade in attached file.
freeze.armbian.txt
just check once again - can confirm freeze on this particular board.
freeze.armbian.txt
Aha, I get it. you need to re-run the script after the upgrade. It is enough with selecting the "System configuration" option.
In order to do it, since you don't have X, try to switch to terminal by pressing Ctrl+Alt+F1, or access through ssh.
rp64, instalation log, kodi breaks os, instalation success, mpv not accelerated, chromium 32bit both installed none streaming media.
Install log attached, did reboot, did disable window manager compositing, kodi desktop link closes x, once you run kodi by command it breaks os have to reflash os, if log doesn't help, i could upload a video since i cant extract system log break atm, video would be easier for me, again by request if needed.
install.log
install.log
Thanks for testing.
The kodi issue can probably be resolved if you switch to nightly builds through "armbian-config".
Now, about acceleration not working, please do the following:
  1. Install the OS, and switch to nightly:
    1. "sudo armbian-config"
    2. Select System->Nightly
  2. Run the script
  3. Reboot
  4. Please post here the output of "ls -l /dev/mali*"
8 hours ago, JMCC said:
Thanks for testing.
  2. Run the script
  3. Reboot
OK, so changed to nightly and nothing happened same results, installed both 5.67 and 5.69 builds (stable builds available at armbian download page old and current) with no avail. noticed that both builds use kernel 4.4.167 even after changing to nightly and updating, upgrading, dist-upgrading nothing changed the Kernel, decided to do it manually and finally was able to change, selected 5.71 build that uses 4.20.0.
Redid instructions and the observations are as follows 4.20.0 does play youtube and media at slightly faster speed (not better i mean like 1.25x) , mpv and chromium 32 played them at correct speed, can see ldspa working but there is no audio so ill blame that on the kernel, neither hdmi or 3.5mm socket have audio output, most likely kernel the culprit again, kodi desktop link does close x and when running command throws error, no longer breaking os so Im attaching error log.
Since changing kernel did make a gr8 difference before I try all the builds to my hearts desire, Im wondering if you have a preferred build version that is better tailored to your script?
Also neither before or after script install / before after updating and upgrading was /dev/mali available
rp64@rockpro64:~$ ls -l /dev/mali
ls: cannot access '/dev/mali': No such file or directory
kodi_crashlog-20190116_023538.log
That is the problem, then.
Im wondering if you have a preferred kernel version that is better tailored to your script?
Well, there are two problems here: 1) RockPro64 uses a different kernel than the other RK3399 boards; and 2) I don't have a RockPro64 to test.
So, in answer to your question, I can tell you that my preferred kernel for all other RK3399 boards is default 4.4.167, but it is because I was able to test and patch that kernel with the required features. It seems like that kernel version, on RockPro64, is not working, and there is not much I can do about it. I think we must consider the possibility of moving RockPro64 to standard RK3399, and then all problems would be solved. But we must make sure before that it is possible to do so without breaking other things.
About this, your script should be possible to run under just Ubuntu Bionic (that was unminimized from servef version) in theory there shouldn't be any problems if kernel is the last version, right?
All software (mpv gstreamer KODI) are collected using system libraries from Ubuntu. Therefore, Ubuntu packages will not work in Debian. We need to rebuild all the components for Debian. I came across this when building KODI versions with HW for AML.
I wasn't asking about Debian at all in my post.
18 hours ago, Dante4 said:
run under just Ubuntu Bionic (that was unminimized from server version)
Only about ubuntu bionic (server edition).
Sorry, I didn't understand your question either. Can you rephrase it?
[EDIT:] If your question is whether the script will work on a server image, with no Desktop installed, the answer is probably not. You can test, but don't expect to get support for it here.
I.e. Is it possible to use this script with "just" Ubuntu Bionic?
I.e.  Why "Armbian Ubuntu Bionic" and not just "Ubuntu Bionic"?
With technical point, not advertise
