Lope Posted January 15, 2019 Share Posted January 15, 2019 These boards are well suited to routing/network traffic control functionality. Currently the kernel has been compiled with Traffic Control stuff disabled, which makes it impossible to perform traffic shaping on stock Armbian kernel. I'm busy recompiling the kernel as a temporary solution, but I will really appreciate it if the kernel build maintainer can please change the traffic control options from DISABLED to MODULE (at least)? I have a bunch of Armbian boards but I'm testing with NanoPi Neo 2 right now. --- I'll let you know the size of the modules once I've finished compiling. 1 Link to comment Share on other sites More sharing options...
Werner Posted January 15, 2019 Share Posted January 15, 2019 You can send a PR with your changes to the kernel config here: https://github.com/armbian/build 1 Link to comment Share on other sites More sharing options...
Lope Posted March 10, 2019 Author Share Posted March 10, 2019 The changes are upstream. You can close this thread now. Link to comment Share on other sites More sharing options...
