Cubietruck - which image to chooe?
John Paden
over year end I tried to re-set up my 2 cubietrucks , one as a a: music machine b) server.
a) Pity is, Volumio is no longer available for Cubietruck - anyone has a later image than 2.118? Any other proposal?
b) When trying to find a workable image for Igors selection, I figured that I run into issues with all of them.
Test 1
Armbian_5.69_Cubietruck_Ubuntu_bionic_next_4.19.13.img
boots
initial input on hdmi,then neither on hdmi nor on VGA  ????
ssh works, login as root works
sudo armbian-config
Boot from SD - system on hdd - works
sudo apt-get update
sudo apt-get upgrade
boot from SD - works, but still 'headless', no signal to hdmi or VGA
-> server starts, but no signal to VGA or HDMI?
Test 2 Same effect with  Armbian_5.69_Cubietruck_Debian_stretch_next_4.19.13.img
Test 3 (for some reason I like to use NAND more than SD)
Armbian_5.59_Cubietruck_Ubuntu_xenial_default_3.4.113_desktop.img
boots
initial input on hdmi,then hdmi works
sudo armbian-config
boot from nand - system on hdd -> works
initial input on hdmi, then hdmi works
sudo armbian-config - apt-get update and upgrade
does not boot any more
-> server starts, but corrupts after first apt-get upgrade?
Test 4 same effect with Armbian_5.35_Cubietruck_Ubuntu_xenial_default_3.4.113_desktop.img
Any idea? What did I miss?
- screen must be attached at boot time.
- if you use some HDMI2VGA converter you might have problems
- images were tested many times and they work fine
- NAND is less reliable than a modern SD card and not supported in modern kernel
