lampra Posted January 30, 2019 Share Posted January 30, 2019 Just updated to v5.73 and no handshakes are reported from wireguard though the connections are up and running. Does anyone else experiences the same issue? root@cubietruck:~# systemctl status wg-quick@wg0 ● wg-quick@wg0.service - WireGuard via wg-quick(8) for wg0 Loaded: loaded (/lib/systemd/system/wg-quick@.service; enabled; vendor preset: enabled) Active: active (exited) since Wed 2019-01-30 00:34:12 EET; 1h 34min ago Docs: man:wg-quick(8) man:wg(8) https://www.wireguard.com/ https://www.wireguard.com/quickstart/ https://git.zx2c4.com/WireGuard/about/src/tools/man/wg-quick.8 https://git.zx2c4.com/WireGuard/about/src/tools/man/wg.8 Process: 1034 ExecStart=/usr/bin/wg-quick up wg0 (code=exited, status=0/SUCCESS) Main PID: 1034 (code=exited, status=0/SUCCESS) Jan 30 00:34:05 cubietruck systemd[1]: Starting WireGuard via wg-quick(8) for wg0... Jan 30 00:34:09 cubietruck wg-quick[1034]: [#] ip link add wg0 type wireguard Jan 30 00:34:09 cubietruck wg-quick[1034]: [#] wg setconf wg0 /dev/fd/63 Jan 30 00:34:09 cubietruck wg-quick[1034]: [#] ip address add 10.200.200.1/24 dev wg0 Jan 30 00:34:10 cubietruck wg-quick[1034]: [#] ip link set mtu 1420 up dev wg0 Jan 30 00:34:12 cubietruck systemd[1]: Started WireGuard via wg-quick(8) for wg0. root@cubietruck:~# wg interface: wg0 public key: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX= private key: (hidden) listening port: XXXXXX peer: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX= endpoint: XXX.XXX.XXX.XXX:XXXXXX allowed ips: 10.200.200.11/32 transfer: 10.84 KiB received, 10.79 KiB sent persistent keepalive: every 24 seconds peer: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX= endpoint: XXX.XXX.XXX.XXX:XXXXXX allowed ips: 10.200.200.4/32 transfer: 2.23 KiB received, 804 B sent persistent keepalive: every 24 seconds peer: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX= endpoint: XXX.XXX.XXX.XXX:XXXXXX allowed ips: 10.200.200.3/32 transfer: 1.19 KiB received, 3.20 KiB sent persistent keepalive: every 24 seconds root@cubietruck:~# wg show wg0 latest-handshakes XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX= 0 YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY= 0 ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ= 0 Link to comment Share on other sites More sharing options...
