Matthew Harding Posted January 30, 2019 Share Posted January 30, 2019 Armbianmonitor: http://www.nourlgiven.com Hello, I have an issue, i am running the Pine LTS board on eMMC using Armbian latest stable image. We want to access the serial port on the board, so to test i downloaded putty, i select serial and click open. I get an error when opening this, so i have to run: sudo chmod 777 /dev/tty50 and sudo chmod /dev/tty52 on each boot, then i am able to open the serial port using putty. When i look at the ls -l /dev/tty50 i get: crw--w---- 1 root tty 4, 50 Jan 30 30 16:07 tty50. After etensive research i added my user cst to the tty group, but when i reboot i still have to manually run chmod again to access the serial port. Can someone please assist me with getting this command to run on boot or some solution as i cannot every time run this command as these boards are Gateways which will be in remote locations. I did try rc.local but i understand that this is not available anymore. I am not too much of a Armbian guru so if you could assist in detailed steps i would appreciate it. No URL is given when i run the armbianmonitor command, it is blank. Thanks! Link to comment Share on other sites More sharing options...
martinayotte Posted January 30, 2019 Share Posted January 30, 2019 42 minutes ago, Matthew Harding said: sudo chmod 777 /dev/tty50 and sudo chmod /dev/tty52 on each boot Those tty are not the one for serial port, you should use /dev/ttyS0, /dev/ttyS1 or /dev/ttyS2. 43 minutes ago, Matthew Harding said: I did try rc.local but i understand that this is not available anymore. Not true ! /etc/rc.local exist on any Linux including Armbian ... Link to comment Share on other sites More sharing options...
guidol Posted January 30, 2019 Share Posted January 30, 2019 40 minutes ago, martinayotte said: Not true ! /etc/rc.local exist on any Linux including Armbian ... but on the original PC (X86/AMD64) port of debian stretch I didnt got a /etc/rc.local I had to create a own rc.local-service or start /home/guido/rc.local via crontab and @reboot but on armbian in the debian stretch version it is every time available. Link to comment Share on other sites More sharing options...
Matthew Harding Posted January 31, 2019 Author Share Posted January 31, 2019 thanks for the replies, i mean S0 and S2. Here is my /etc/inid.d/rc.local !/bin/bash -e ### BEGIN INIT INFO # Provides: rc.local # Required-Start: $all # Required-Stop: # Default-Start: 2 3 4 5 # Default-Stop: # Short-Description: Run /etc/rc.local if it exist ### END INIT INFO echo "running rc.local"> /tmp/rctest.txt sudo chmod 777 /dev/ttyS0 sudo chmod 777 /dev/ttyS2 exit 0 Is there something i am missing here? Link to comment Share on other sites More sharing options...
