UnixOutlaw Posted February 1, 2019 Share Posted February 1, 2019 Banana Pi (original "model 1") A20 Was running flawlessly on Xenial - latest updates - almost everything worked (I run it on a LiPo battery to transport back and forth from work to keep my Resilio Sync data "in sync") Resilio seems to work fine - except in Bionic I can't use avahi to resolve names on my LAN... this worked in Xenial on the same hardware. The reason I decided to try out Bionic? Couldn't find a resource to upgrade from OpenSSH 7.2 to 7.3 or greater (I'm making heavy use of features not available in OpenSSH 7.2 on my other machines). I've tried tweaking my /etc/nsswitch.conf file to no avail... Sheesh - "avahi" just worked out of the box on Armbian Xenial - and it works out of the box on Bionic on x86_64... Works out of the box on Raspbian Stretch on my RPi 3B. Works out of the box on Armbian 5.6 (Xenial) on my Orange Pi+ 2E... Qualification : avahi works on the Banana in that other hosts can reach it (e.g. "ping ffrwchnedd.local" works from any other machine) - so it's announcing itself on my LAN, but it cannot use avahi to reach other hosts by hostname.local (no problem pining actual IP address of other devices). If I can't resolve this soon - I'll go back to Xenial and try and figure out how to do some version control on my ~/.ssh/config file(s) (I have a common one symlinked from my Resilio Sync folders). P.S. I didn't upgrade in place - I just booted from a fresh flashed SD card so I can backout to Armbian 5.6 Xenial without too much pain (other than re-syncing 130 GB of Resilio Sync folders - stored on 256 GB USB drive). Link to comment Share on other sites More sharing options...
UnixOutlaw Posted February 2, 2019 Author Share Posted February 2, 2019 Update : it's not working on any of my Armbian machines... doesn't work on Xenial Armbian 5.7 on bananapi, or Xenial Armbian 5.6 on orangepi+ 2E... those machine names can be resolved from other hosts on the LAN, but they themselves are unable to resolve other machine names on my LAN. I could have sworn it was working previouisly. Close this topic - clearly not related to Armbian Bionic... I have no idea what's going on... Link to comment Share on other sites More sharing options...
martinayotte Posted February 2, 2019 Share Posted February 2, 2019 I'm running Armbian Stretch on all my boards, and avahi-daemon is working on all of them, although default setting is "publish-workstation=no", I have to change to "yes" to make them visible in avahi-browse. Link to comment Share on other sites More sharing options...
UnixOutlaw Posted February 4, 2019 Author Share Posted February 4, 2019 thanks for that info - the issue I have with Armbian, I can resolve the Armbian hosts on my LAN from other machines (all Linux), but from Armbian itself I can't resolve other host's names... Not 100% sure what "publish-workstation" does - but it kinda sounds like advertising itself on the LAN? Anyway I reset that to "yes" on a Linux laptop (x86_64) and on Armbian, and it's the same as before... I might try out stretch then... avahi works out of the box for me on Raspbian Stretch... Link to comment Share on other sites More sharing options...
devman Posted February 4, 2019 Share Posted February 4, 2019 I had to change the entry in my /etc/nsswitch.conf to include "mdns4_minimal" in the "hosts: " line so it would resolve blahblah.local addresses Link to comment Share on other sites More sharing options...
UnixOutlaw Posted February 5, 2019 Author Share Posted February 5, 2019 22 hours ago, devman said: I had to change the entry in my /etc/nsswitch.conf to include "mdns4_minimal" in the "hosts: " line so it would resolve blahblah.local addresses Already tried that - still won't resolve hostnames on my LAN (two different LANs - my home LAN and my work LAN)... NSSWITCH usually one of the first places I look (hangover from Solaris)... hosts: files mdns4_minimal dns myhostname Also - noticed some wildly different results from /sys/power/axp_pmu/battery/ output compared to Armbian Xenial on the same hardware... I don't know if that's because Bionic is drawing more power and battery never gets to 100%... but its always around 96% and always "discharging" ╰─➤ cat /sys/power/axp_pmu/battery/capacity 96 ╰─➤ cat /sys/power/axp_pmu/battery/charging 0 Link to comment Share on other sites More sharing options...
