Touch screen in Pine64
icce
Mainline stable Armbian stable for Pine64 worked great.
I have successfully make my 3.5 TFT screen work but not the touch screen. I read some tutorials,  mostly guide.
This guide for TFT and Touch is really detailed. For touch:
- Step 1: ads7846 driver seems ok
- Step 2: ads7846_device there is a warning after make and make install, and it said to skip depmod
- After this, I tried
sudo modprob ads7846
sudo modprob ads7846_device model=7846 cs=1 gpio_pendown=1 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900
ads7846 is ok (confirmed with lsmod).
But ads7846_device return invalid argument, it means that module ads7846_device is not in the system.
Anyone succeed with Pine64?
Follow my attempt to make touch work on Pine64.
I confirmed that "ads7846" and "ads7846_device" already installed. Even though there was a warning about missing "system.map" but it seems those modules have been installed.
lsmod and ads7846 was there but not ads7846_device.
I tried
dmesg | grep ads7846
but it gave error:
ads7846_device: Unable to get IRQ assigned to gpio_pendown'
It seems that Armbian Mainline on Pine64 has not configured assign interrupt for pin?! Or kernel for Pine64 cannot IRQ for GPIO71
sudo modprobe ads7846_device model=7846 cs=1 gpio_pendown=71 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900
Any idea?!
