Devocion Posted February 20, 2019 Share Posted February 20, 2019 (edited) I downloaded Armbian_5.59_Orangepizero_Ubuntu_xenial_default_3.4.113.img, and am running it with a 16GB SD card. I am trying to modify the I2C settings, however, when I type `armbian-config`, and select `System`, there is no "Hardware" menu option. This contradicts the documentation: Hardware is supposed to be an option in that menu. This is the current content of the /boot/armbianEnv.txt: verbosity=1 console=both overlay_prefix=sun8i-h3 overlays=usbhost2 usbhost3 rootdev=UUID=54dfde69-e472-48dd-a099-636a963154f3 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Edited February 20, 2019 by Devocion Link to comment Share on other sites More sharing options...
Igor Posted February 20, 2019 Share Posted February 20, 2019 It works, but sometimes it doesn't: https://github.com/armbian/config/issues/33 Link to comment Share on other sites More sharing options...
Devocion Posted February 21, 2019 Author Share Posted February 21, 2019 Any ideas why it does or doesn't? I've tried with both new SD cards, new Pis, and both copies of a saved, modified .img as well as the fresh .img, and haven't yet seen Hardware as an option Link to comment Share on other sites More sharing options...
Devocion Posted February 21, 2019 Author Share Posted February 21, 2019 @Igor I think this is different than the issue 33 that you linked to, because that issue allows the user to select Hardware, but once selected, all the entries are empty. My case is different because Hardware isn't even an option in the System settings: Link to comment Share on other sites More sharing options...
Devocion Posted February 21, 2019 Author Share Posted February 21, 2019 I was able to resolve it by installing the following package: linux-dtb-dev-sun8i. If you have the same issue, I'd recommend running: apt install linux-dtb-dev-sun8i Link to comment Share on other sites More sharing options...
Igor Posted February 23, 2019 Share Posted February 23, 2019 On 2/21/2019 at 8:01 PM, Devocion said: If you have the same issue, I'd recommend running: Well, this means you have break system due to upgrading a kernel package and not installing DTB. For a DEVelopment kernel. Clean images must come with this package. Link to comment Share on other sites More sharing options...
