0
liwanda
Nanopi Duo USB CAM Error
I connected FA-CAM202 ( 2M USB cam provided by FriendlyArm) to USB2 pins on Nanopi Duo,
The OS is  Armbian Bionic mainline kernel 4.14.y
The V4l applications output error as
  Unable to start capture: Input/output error
   i: Error grabbing frames
The dmesg shows
  uvcvideo: Failed to query (GET_CUR) UVC control 3 on unit 1: -32
  uvcvideo: Failed to set UVC commit control : -32 (exp. 26)
This Cam FA-CAM202 is worked on PC while other USB CAM such as Logitech works on the same
configuration of Nanopi Duo, on USB2.
สมัคร138bet
Share this post
Link to post
Share on other sites
0
