Mustafa85 Posted March 20, 2019 Share Posted March 20, 2019 Hi, Recently I have installed "Armbian_5.75_Orangepizero_Debian_stretch_next_4.19.20" on my OrangePi Zero . I configured both Ethernet and wifi connection but I had a problem with the wifi, my board does have an IP address but I can not connect through ssh nor pinging that IP. The connection is Ok and I can get access to internet but I can not ping from any other devices on the network (error Destination host unreachable), But I noticed that if I ping (from the orangepi board ) the host machine then I will be able to connect through ssh to that IP. I dont know if its a problem with arp last thing that I tried was to disable the network manager but I still have the same issue. Link to comment Share on other sites More sharing options...
guidol Posted March 21, 2019 Share Posted March 21, 2019 check with nmtui your ip address - there should be a /24 at the end of the ip of your OPi Zero..... like 192.168.7.8/24 but only for the ip of your zero and not at the gateway or dns-ip I got tge same like problem, because if you enter only the ip for your zero in nmtui then nmtui will add a /32 when you do save the connection and then your zero is very "lonely"... 1 Link to comment Share on other sites More sharing options...
Mustafa85 Posted March 21, 2019 Author Share Posted March 21, 2019 Thank you very much, you save my 10 days work .... perfectly work 1 Link to comment Share on other sites More sharing options...
