Hello everybody! There is a big problem with the Banana PI Pro. The system is installed on the micro SD, when updating the packages I get the following result:
root@bananapipro:~# apt-get install mdadm
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
libc6-dev : Depends: libc6 (= 2.19-18+deb8u9) but 2.19-18+deb8u7 is to be installed
E: U
Can you please provide the output of the following running with 4.9 kernel:
cat /sys/power/axp_pmu/{ac,vbus}/voltage
And then also from
stress -c 1 & sleep 1 && cat /sys/power/axp_pmu/{ac,vbus}/voltage && pkill stress
