Hello, I have tested Armbian with SD card without issue.
I'm wondering if it's possible to do the same using SSD.
SSD is much more reliable and faster than SD card.
I can do it with the Ubuntu release from Odroid using petitboot, but it seems that Armbian isn't compatible with petitboot.
Thank you
Added file "set_order_boot.ini " to quickly configure SPIboot in the desired order of scanning (starting) media. The script initially specified settings for the default option ( with such settings comes SPIboot initially). To change the order, you need to edit this script, rename it to "boot.ini" write to any medium and run N2 with it. The script will automatically change the desired settings and turn off the system.
Parameter "rawimage" means eMMC
For example, you need to spe
